'10-'12 vs '13-'14 dampers - Subaru Outback - Subaru Outback Forums
 1Likes
  • 1 Post By dat2109
post #1 of 9 (permalink) Old 04-15-2019, 09:19 AM Thread Starter
I have an early 3.6R and am confused about aftermarket damper availability...
Originally there was little choice...OEM or KYB Excel-G, period (and OEM is made by KYB).
Then the revamped OEM suspension came out ('13/'14), which was reportedly stiffer.
And now I see that there are a couple more aftermarket options available (Cusco and Bilstein), but both are listed only for the later cars.
I am under the impression that the later OEM dampers are a direct swap into the earlier cars. If so, then the aftermarket stuff should be as well, yes? Primitive does list the Cuscos as an option for '10-'14 (and a Cusco doc I found indicates the same part numbers), so I guess that's confirmation?
Here's the root of the question:
I've been running Rallitek lift/load springs for a little while now (+1"F / +1.5"R) and while I am very happy with the lift results and performance when loaded, they are just too much spring for the current dampers when unloaded. Compression is fine, but the car really kicks in rebound. I should mention that the springs went in as part of completely new strut assemblies...these are not new springs on tired dampers. I used OEM group N tophats and the Excel-Gs.
I need more rebound damping, in the rear especially. Can anyone speak to the performance of the Bilstein (B6) or Cusco (Touring A)? Cusco is adjustable (unclear in what way) and claims "140% stiffer" at max setting. Bilstein does not give specifics.
Thanks for any/all info!
dookie is offline
post #2 of 9 (permalink) Old 04-15-2019, 10:54 AM
RegalX's Avatar
Car: 2010 2.5 Premium
I am also interesting in knowing the actual difference between the years. I've heard it mentioned here a bunch of times but no one has given specifics. Rock Auto lists two different Monroe dampers 10-12: MONROE 72691. 13-14:73039. Not sure how those compare to the KYB:10-12 KYB 340027 13-14: KYB 3410030.
RegalX is offline
post #3 of 9 (permalink) Old 04-15-2019, 05:19 PM
dukey33's Avatar
Car: 2010 2.5 CVT Premium
I am interested in some answers as well.
I pulled this data from rock auto's pages. The two are close, but not exactly the same. The differences are more than just internal valving (most interesting is the additional 1.5in travel). But is it close enough to use the updated part in the older 4thgen? And can the 10-12 springs be used in the 13-14 strut?
MONROE 72691('10-'12)
Body Length (in.)13.050
Body TypeSS2
Dust ShieldNo
Extended Length (in.)19.000
Compressed Length (in.)14.750
Travel Length (in.)4.250
Parts Pack(s)None
Cylinder IncludedNo
Compressed Bumper StopNo
Extended Bumper StopNo
Extended Hydraulic LockoutNo
Upper Mounting DescriptionStem Mount - 1.3/16" Stem Length X M10 Thread Pitch
Strut Charging TypeGas Charged Unit - Strut Rod Will Extend Automatically
MONROE 73039 ('13-'14)
Body Length (in.)13.110
Body TypeSS2
Dust ShieldNo
Extended Length (in.)19.397
Compressed Length (in.)13.661
Travel Length (in.)5.736
Parts Pack(s)P0906
Cylinder IncludedNo
Reserve Tube Diameter (in.)1.744
Extended Bumper StopYes
dukey33 is online now
post #4 of 9 (permalink) Old 04-15-2019, 05:48 PM
RegalX's Avatar
I emailed KYB and will try and call Monroe again tomorrow. Doubtful they will have answers, but we'll see. Also inquired with Rallitek.
RegalX is offline
post #5 of 9 (permalink) Old 04-16-2019, 10:28 AM
RegalX's Avatar
From KYB:
Fitment of both struts is more or less the same, the primary difference is that 3410030 is about 0.2” longer in extended length. 3410030 also has about 15% higher damping that 340027 that we list for the 2010 Outback. We haven’t tested the strut for the newer models on the older vehicle, but you likely could use it on your vehicle.
I am getting some Rallitek RTEK-830-521-355 rear springs and will be buying the 3410030 (13-14) dampers.
RegalX is offline
post #6 of 9 (permalink) Old Yesterday, 08:15 AM
I've been watching the Bilstein offerings after looking for alternatives to the KYB's and finally got my hands on a set a few days ago. I went with the stiffer HD's - I've had good experiences with them on other cars.
HeyChris likes this.
dat2109 is offline
post #7 of 9 (permalink) Old Yesterday, 08:21 AM Thread Starter
These are the B6s? On what year car?
dookie is offline
post #8 of 9 (permalink) Old Yesterday, 01:35 PM
Yep, B6's. They are going to go on a 2015.
According to Bilstein they have a fitment for the Gen4 outbacks too. They list the B4 part numbers as 2010-2014 and the B6 part numbers as 2013-2014. I would be surprised if you had trouble interchanging them, they might just be too much damper for the soft springs in the early years.
dat2109 is offline
post #9 of 9 (permalink) Old Yesterday, 01:42 PM
Fitment for 2010-2012
Fitment for 2013-2014
dat2109 is offline
2005-2009 Outback Suspension FAQ phatvw Gen 3: 2005-2009 1583 04-04-2019 12:06 PM
With RalliTek rear springs I like Gen2 rear dampers phatvw Gen 3: 2005-2009 31 09-06-2016 09:22 AM
Stablex suspension dampers on Limited. Major or minor Improvement? Harplayr Gen 5: 2015-2019 4 08-06-2015 12:49 PM
are the stock 2000OBW dampers monotube? hustler Wheels, Tires, Brakes, & Suspension 0 07-15-2007 08:41 AM
Dampers & Pogo AndroXT Wheels, Tires, Brakes, & Suspension 1 02-12-2006 05:13 PM
