Erratic door unlocking - passenger front door - Subaru Outback - Subaru Outback Forums
 1Likes
post #1 of 17 (permalink) Old 02-23-2019, 03:39 PM Thread Starter
Greenmamba's Avatar
Car: Outback 2006 3.0Rn 5EAT Wagon.
Question Erratic door unlocking - passenger front door
Here's hoping someone has trod this path before and found a cure. My (right hand drive) 2006 OB has an intermittent problem with remote unlocking of the front passenger door. Every 10 or so times, using the factory supplied single button, central locking fob to unlock the car, only the pax side front door wont unlock. Trying the inner handle does nothing. Trying the outer handle, ditto. All other doors work fine. Eventually, after a couple/few/several times (varies) pushing the fob button, the door unlocks (hear a slight click when it does, then you know it's worked). Normal service returns until the next time.
Any ideas? I guess the door card will have to come off, just asking for pointers if there's anything specific I should focus on?
Nikinikitembonosorembooohmamuchigummagummaguchi
Greenmamba is online now
post #2 of 17 (permalink) Old 02-23-2019, 04:05 PM
Car: 2008 Subaru Outback Base. 2005 Subaru Outback 2.5i. 2013 Harely-Davidson FLHTK.
Sounds like a problem with the actuator. What happens if you use the button on the drivers door to lock and unlock?
BTIBob is offline
post #3 of 17 (permalink) Old 02-23-2019, 04:09 PM Thread Starter
Greenmamba's Avatar
Hi. Tried it, no joy. Tried the unlock button on the pax door from the inside, also fails to unlock - move it to the unlock and it springs back to the lock.
post #4 of 17 (permalink) Old 02-23-2019, 04:35 PM
It's the electric actuator or linkage in the door.
This is the part you need:
https://parts.subaru.com/p/Subaru_20...1100AG01A.html
BTIBob is offline
post #5 of 17 (permalink) Old 02-23-2019, 04:45 PM
sgoti's Avatar
Car: 2005 Outback 2.5i, Auto Transmission, 270k+
Bad actuator motor in the passenger side door? I had a similar problem on the driver's side rear door right after I purchased my Outback (2005i).
Quick fix was to take a gamble on buying another lock actuator from the junkyard. That worked, but also started me on a program to go through and replace the motors in ALL my actuators (it wasn't that expensive, and I didn't want another actuator to fail at an inconvenient time.)
If you do decide to replace the motors (I think the brand was Mabuchi), just make sure the shaft down not stick out too far from the rear of the motor. I ended up having to grind mine down a small amount after I determined they were binding on the actuator enclosure.
2005 2.5i, automatic
sgoti is online now
post #6 of 17 (permalink) Old 02-24-2019, 03:48 AM Thread Starter
Greenmamba's Avatar
Thanks! Waiting for a bit of warmer weather and I'll dig in to it. Unfortunately, spares here (UK) are much pricier than in the US so I'll likely strip the motor (if it's openable) and check brushes/commutator etc.
post #7 of 17 (permalink) Old 02-24-2019, 03:49 AM Thread Starter
Greenmamba's Avatar
Cheers, will look at what is installed and see where we go from there. I'll try and report back but it'll likely be a few weeks.
post #8 of 17 (permalink) Old 02-24-2019, 10:08 AM
I believe it's more of a solenoid than a motor.
BTIBob is offline
post #9 of 17 (permalink) Old 02-24-2019, 10:52 AM
Feedback Score: 11 reviews
The lock actuator is a small, DC motor. The keyless entry control applies 12 V to the motor for about 2 seconds. The motor turns a set of gears that switches the lock mechanism. Lock, or unlock action is determined by the polarity of the 12 V applied to the motor by the control.
There's photos of the actuator in post #2 of https://www.subaruoutback.org/forums...placement.html.
plain OM is online now
post #10 of 17 (permalink) Old 02-24-2019, 11:12 AM
Well..... I just learned something new today!
BTIBob is offline
2005 Outback Rear Passenger Door Mechanism Snapped - Child Lock Engaged! tastyorange Problems & Maintenance 31 11-21-2016 06:26 PM
HELP! Seeking opinions: 2006 Outback 3.0R vs 2009 Outback 2.5i Limited Bulldawg23 Gen 3: 2005-2009 45 05-02-2016 04:51 PM
WTB: Passenger Side Garnish Door Sniderd Classifieds 7 06-15-2015 03:34 PM
Noise in 2007 OBW passenger side door? EW08 Problems & Maintenance 0 01-07-2007 02:04 PM
Any ideas on raising the front passenger seat 1" to fit a Kenwood sub? eno Audio, Video, Security, & Navigation 5 10-04-2006 11:42 PM
