Dash Battery light on - Page 2 - Subaru Outback - Subaru Outback Forums
 4Likes
post #11 of 20 (permalink) Old 04-11-2019, 08:06 PM Thread Starter
Originally Posted by dryvby View Post
Ooof! careful when doing that, that can spike the system. Not recommended with modern cars.
Originally Posted by Tishers View Post
Yea, the battery acts sort of like a capacitor for your vehicle's electrical system;...
I do get that but never thought of it being an issue if disconnecting the batt cable when running. Voltage was ~14.5 when we measured it several hours ago and the dash light was off. Replacement/reman alternator is here on the bench and we will see how it goes the next few days and install it if necessary. I might keep it and not return since we own three of these vehicles and they are getting older now.
Any recommendations on better or best replacement alternator choices?
59ctd is offline
post #12 of 20 (permalink) Old 04-11-2019, 08:50 PM
Feedback Score: 11 reviews
Originally Posted by 59ctd View Post
. . . Voltage was ~14.5 when we measured it several hours ago and the dash light was off.
As it should be.
Incidentally, the Battery warning light can also be on if the alternator output voltage is high, as when the alternator is generating but isn't being controlled by the regulator. In this case, the bulb brightness will depend on the difference between the (average/pulsed) alternator output voltage and the battery voltage. It's often less bright than when the ignition is at On but the engine isn't started or when the alternator stops generating, and tends to vary noticeably with engine speed.
In either case, when the light is on, a voltmeter can be used to verify what's happening.
plain OM is offline
post #13 of 20 (permalink) Old 04-11-2019, 09:04 PM
. . . Any recommendations on better or best replacement alternator choices?
One of the problems with "rebuilt" or "remanufactured" alternators is just what is replaced during the process. For example, does the rebuilding factory always replace the regulator with a new one, or is it replaced only if the recycled alternator exhibits a faulty regulator symptom at the factory? Would it test all alternators sufficiently to identify an intermittent regulator? Guess who might end up doing the quality control in that case . . ..
In the past, @eagleeye has recommended newly-built alternators from DB Electrical (https://www.dbelectrical.com/). Not sure what the situation is now, but perhaps this is still an alternative.
plain OM is offline
post #14 of 20 (permalink) Old 04-11-2019, 09:32 PM
Just another thought:
The alternator regulator "senses" the system voltage through fuse #17 (7.5 A) in the engine compartment fuse box. I'm not certain, but if that fuse blows, or develops an intermittent connection, leading to no voltage feedback to the alternator, it's possible that too could cause the alternator to max out. In this case, the high voltage output isn't due to a fault in the alternator. It might be an idea to replace fuse #17 with a new one to be sure the connections between the fuse blades and the fuse box contacts are good.
plain OM is offline
post #15 of 20 (permalink) Old 04-11-2019, 09:54 PM
eagleeye's Avatar
similar to the new ones from DB: there is also Maniac in Texes,
and rounding up the real Mitsubishi USA ones. (if that was the factory original in 2009 LGT)
eagleeye is offline
post #16 of 20 (permalink) Old 04-12-2019, 01:12 AM
Car: Outback 2011 3.6R Premium
The brushes in your alternator are probably almost worn out. When this happens sometimes they are making contact and sometimes they are not.
Seagrass
MY11 Outback 3.6R Premium (Daily drive)
MY06 Forester XT 2.5 (Youngest daughter driving)
MY07 Liberty/Legacy 2.5 (Eldest daughter)
MY04 Impreza RS 2.5 (Sold Jan 2019)
MY02 Impreza 2.0 (Son in Law)
seagrass is offline
post #17 of 20 (permalink) Old 04-12-2019, 08:11 AM Thread Starter
Seagrass
Makes sense. What is the expected life of alternator brushes?
59ctd is offline
post #18 of 20 (permalink) Old 04-15-2019, 12:47 PM Thread Starter
Started it up again today and dash battery light is on again. My son and I measured system voltage and it was 11.7. Replacement alternator is in took only ~10 mins for us and it appears the issue is solved now. We have 14.5 volts now. Are modern alternators typically short on life expectancy. In the past I am used to them going for way longer than 66k.
59ctd is offline
post #19 of 20 (permalink) Old 04-15-2019, 01:54 PM
Probably a random failure rather than a pattern.
Incidentally, when the Battery warning light was on, did the Brake warning light come on as well (if it wasn't already on because the parking brake was being applied)? It should have.
plain OM is offline
post #20 of 20 (permalink) Old 04-15-2019, 06:12 PM Thread Starter
Yes, the brake light was on as well.
plain OM likes this.
59ctd is offline
Another Battery Light+Brake Light on Dash Desert Problems & Maintenance 6 08-22-2015 11:10 PM
2003 Outback Limited and airbag light vs. battery delfuego Problems & Maintenance 1 01-18-2011 02:28 PM
Cruise dash light? drcolt Electrical & Electronics 4 09-22-2007 02:08 PM
How many forum members does it take to change a light bulb? FastSly The Village 5 01-25-2006 09:46 AM
