Dash Battery light on - Subaru Outback - Subaru Outback Forums
 4Likes
post #1 of 20 (permalink) Old 04-11-2019, 12:44 PM Thread Starter
Car: 09 Legacy GT, 08 Legacy 2.5i, 09 Outback 2.5i
09 LGT. What condition might cause the battery light on the dash to be on just after starting? Car has been inside ~66* all night so it is not cold like outside. Started it to swap two cars and the battery light is on now. Battery was replaced in January. I hit a huge pothole yesterday during the snowstorm and was worried about suspension but that all looked fine. I don't see how an alternator issue could be related. Thoughts?
59ctd is offline
post #2 of 20 (permalink) Old 04-11-2019, 12:48 PM
Tishers's Avatar
Car: 2007 2.5 L Obsidian Black Outback XTL
A bad alternator that is not charging the car can create a BAT light.
Greetings from the leading factory authorized interocitor service center of the Milky Way galaxy for the last three millennia. If you are in the Orion arm stop by to see the latest models. Now with interdimensional mutate capabilities!
Sol system, third primary planet. (Excuse our mess! Just ignore the bipedal life forms, their extinction is under way).
Tishers is offline
post #3 of 20 (permalink) Old 04-11-2019, 12:51 PM
Car: 2017 Outback 3.6 Touring, which replaced '05 Outback XT
The light means the alternator isn't charging. Hard to say whether it is related to the pothole.
I had a pothole ruin a battery by breaking an internal connection, but since your car started, I doubt that is your problem. Old batteries are more susceptible to mechanical failure.
Radar is offline
post #4 of 20 (permalink) Old 04-11-2019, 01:03 PM Thread Starter
I started it and disconnected the battery and it died so yep I think I need a new alternator...
59ctd is offline
post #5 of 20 (permalink) Old 04-11-2019, 01:13 PM
Subie19's Avatar
Car: 2019 Subaru Outback Touring 3.6R Wilderness Green
If you have a multi meter you can check it if your alternator is working, your reading should be higher than 12. Volt maximum 15.6 volt when you rev your engine. If the the reading stay 12 volt or lower, yes your alternator I'd bad.
59ctd likes this.
[/Retired
[/2019 Outback 3.6R Touring]
[/2015 Toyota Tacoma Pre Runner Limited]
[/2012 Outback 3.6R Limited]
[/2005 Honda CRV EX AWD]
[/2003 Mercedes Benz C320 Sport]
"Life is too short, Lets enjoy it"
Subie19 is online now
post #6 of 20 (permalink) Old 04-11-2019, 02:01 PM Thread Starter
My son and I just picked up a reman alternator and I will pull my car into the shop again for the swap when my daughter leaves for work in a few hours. The car she drives (08 2.5i) was totally packed and piled with snow from this spring blizzard so it is thawing out in shop now. I will check the running voltage when I get it back in here. I am not a fan of reman parts but hopefully this does the trick. It certainly looks like reasonable quality.
59ctd is offline
post #7 of 20 (permalink) Old 04-11-2019, 02:14 PM
dryvby's Avatar
Car: 05 Xt beatin' to an inch of its life
Ooof! careful when doing that, that can spike the system. Not recommended with modern cars.
plain OM and AvidHiker like this.
dryvby is offline
post #8 of 20 (permalink) Old 04-11-2019, 03:04 PM
Tishers's Avatar
Yea, the battery acts sort of like a capacitor for your vehicle's electrical system; It smooths out many voltage spikes that can originate from the alternator. Disconnecting the battery did confirm indeed that you have a bad alternator that is not putting out enough current to even keep the car alive but generally you are gambling whenever you disconnect the battery like that.
Remanufactured alternators are usually a safe item to buy; When alternators go bad it is usually a mechanical problem like bad bearings. Electrically it will be bad diodes or a bad winding. Diodes can be replaced... bad windings... those are more challenging and most people who attempt to fix windings are mere "hacks" who have no idea what they are doing.
Tishers is offline
post #9 of 20 (permalink) Old 04-11-2019, 03:21 PM Thread Starter
Head Scratcher...
Put the car in the shop a few mins ago and my son and I checked it out. This is before starting any work on it. No alt/batt light now and it runs fine with battery neg disconnected. Unsure what the issue (if any) might be. Argh...
59ctd is offline
post #10 of 20 (permalink) Old 04-11-2019, 04:33 PM
Feedback Score: 11 reviews
Not unusual for alternator regulators to develop an intermittent problem. If it works now, it might not work later. But I guess you could watch it for a while to see if the symptom reappears.
Back to the disconnected battery. The alternator could be applying higher voltage to the rest of the car's electrical system -- something in the range of 17-24 V, or more. That could damage critical functions, as well as stress simple things like light bulb filaments.
The alternator regulator works by controlling the current through the alternator rotor winding. As the rotor turns, the magnetic field generated by that current passes over the field winding, which generates an AC voltage and corresponding current that is connected through rectifying diodes to the alternator output terminal. The voltage from the field winding itself is not controlled; instead, the regulator turns the rotor winding current on and off fairly rapidly, with the on times longer when the battery is not fully charged, and shorter when it is. This results in a pulsed output from the alternator that goes between zero and somewhere above ~17 V. The pulses can be accompanied by spikes of voltage far higher. When the battery is connected, as was mentioned by others, the battery smooths out the pulses by absorbing the excess energy being output by the alternator. When the battery is disconnected, the pulses, and spikes, are not controlled.
Disconnecting the battery is not a way to test the alternator. A simple multimeter would be adequate to check if the alternator is working.
plain OM is online now
Another Battery Light+Brake Light on Dash Desert Problems & Maintenance 6 08-22-2015 11:10 PM
2003 Outback Limited and airbag light vs. battery delfuego Problems & Maintenance 1 01-18-2011 02:28 PM
Cruise dash light? drcolt Electrical & Electronics 4 09-22-2007 02:08 PM
How many forum members does it take to change a light bulb? FastSly The Village 5 01-25-2006 09:46 AM
