2004 EJ259 engine repair thread - Subaru Outback - Subaru Outback Forums
 7Likes
post #1 of 81 (permalink) Old 09-27-2017, 12:27 PM Thread Starter
rx7145's Avatar
I bought a 04 Outback with a broken timing belt for $400.
I'm in the early stages of fixing it.
Since I'm going to be installing a new timing belt what kit do most people use? Hopefully from rockauto.
My plan is to try a new belt if that does't work take off the heads and see the carnage. May just end up replacing the engine.
Thanks.
OutHack and Bgilly like this.
rx7145 is offline
post #2 of 81 (permalink) Old 09-27-2017, 12:36 PM
most people concentrate on trying to get Japanese bearings in the rollers.
OEM or NTN tensioner
OEM or Mitsuboshi belt
OEM or Aisin waterpump if doing it
some say OEM only on cam/crank seals (brown-colored?)
check rockauto, amazon, on ebay check; mizumoauto or autoeverything(?), , etc
fredbeansparts, subarugenuineparts, subaruparts4you etc are on-line dealers. Local dealer may match prices of on-line dealers.
1 Lucky Texan is offline
post #3 of 81 (permalink) Old 09-27-2017, 02:22 PM Thread Starter
rx7145's Avatar
Ok I got a Mitsuboshi belt coming. Thanks!
1 Lucky Texan likes this.
04' Outback Auto
rx7145 is offline
post #4 of 81 (permalink) Old 09-27-2017, 02:54 PM
the toothed idler is often in worse condition than the belt - most folks will replace all the idlers when they do the belt. If the car has a lot of miles (175-200K) or is of unknown background, doing the tensioner and probably the water pump is a good idea too.
it's an interference engine, just doing a belt slap is risky.
post #5 of 81 (permalink) Old 09-27-2017, 05:32 PM
Car: 01 Outback LL Bean
I would do the Aisin kit on Rockauto with waterpump.
1 Lucky Texan and miker104 like this.
Glennda5id is offline
post #6 of 81 (permalink) Old 09-27-2017, 07:24 PM
eagleeye's Avatar
is that a 2004 regular EJ251,
or the weirdo 2004 EJ259 california spec?
(see build plate under the hood on the shock tower in front of the driver)
eagleeye is online now
post #7 of 81 (permalink) Old 09-29-2017, 02:44 PM Thread Starter
rx7145's Avatar
Its the EJ259. But the engine has been changed at some point.
Whats the difference?
rx7145 is offline
post #8 of 81 (permalink) Old 09-29-2017, 03:04 PM
eagleeye's Avatar
from the older EJ251 design, a
Ej259 is like half a step to the later EJ253,
so you get special heads, pistons, intake, exhaust as a single year thing. (and only on legacy and legacy outback)
not fun to find major parts for,....and may present unique diagnostic issues (always have to state it is a cal -spec car,...when doing work, as it has unique sensors).
post #9 of 81 (permalink) Old 10-01-2017, 06:52 PM Thread Starter
rx7145's Avatar
I wounder if the correct engine was swapped in.
04' Outback Auto
rx7145 is offline
post #10 of 81 (permalink) Old 10-01-2017, 07:01 PM
eagleeye's Avatar
could have a Ej251,...a EJ259....or a EJ253.
I posted pics of each of them here:
https://www.subaruoutback.org/forums/...ml#post3964714
(notice the plastic airbox, and intake differences between the 3).
