H6 stutter - Page 2 - Subaru Outback - Subaru Outback Forums
 1Likes
post #11 of 19 (permalink) Old 03-26-2019, 10:04 AM
aesthetic.rake's Avatar
Car: 2006 OutBean, 2005 LGTW
Originally Posted by guntherrex View Post
Since the plugs were changed at the subaru dealership I assume they used th correct spark plugs... otherwise I'd be rather disappointed. I could ask of course
what's a MAP/MAF?
it runs on 95 octane fuel, no LPG.
Mass air flow. It's the electrical dohicky just on the engine side of the air cleaner. They make a particular spray you can buy at the parts house. Mass air flow sensor cleaner. I don't know what else can be used. MAF spray could just be marketing wank.
Current cars: The Sex Wagon 2005 Legacy GT Wagon w/ 5 speed, Stage 2, TBSTI Bilsteins/STI Pinks and Whiteline everything else. The Outbean 2006 Legacy Outback LLBean 3.0r, All stock The Workhorse 2001 Toyota Tundra SR5 New Project 2009 2.5i SE--Blown Headgaskets
Past cars: 2001 Outback 2.5 Limited, 2003 Outback LLBean h6, 2008 Outback 2.5 base, 2010 Legacy 2.5i Premium w CVT, 2003 BMW 330CI, 2011 Subaru Outback 2.5i Premium
aesthetic.rake is online now
post #12 of 19 (permalink) Old 03-26-2019, 10:39 AM
other products MAY be OK, but to me, the MAF cleaner I bought smelled unique among automotive products - most like that wall stain primer KILZ I think - maybe a lacquer thinner-ish odor?
1 Lucky Texan is offline
post #13 of 19 (permalink) Old 03-27-2019, 04:48 AM Thread Starter
Car: 2001 outback H6 3.0 VDC
you guys in the habit of sniffing cleaning agents?
I asked the mechanic, he said the sensor readings were within spec
guntherrex is offline
post #14 of 19 (permalink) Old 03-27-2019, 08:33 AM
sometimes smelling stuff is unavoidable
sometimes it smells kinda good! lol
post #15 of 19 (permalink) Old 03-27-2019, 10:59 AM
Car: 01 Outback LL Bean
In my experience the TPS can be an issue in these cars. It might be difficult to catch and I would recommend replacing as there was a defect with the original part. You might be able to check the part number of your TPS.
I used to have issues under load occasionally that I think was due to issues with the timing chain tensioners that were failing. It should also be noted that these cars should have the valves adjusted at 100k miles and valves out of adjustment could lead to misfires under certain loads. Honestly, checking and adjusting the valves its a big time consuming task and not recommend unless the heads are being pulled.
These cars do not have a MAF airflow sensor. They will not succumbed to vacuum leaks especially at 2k rpm.
If it was a fuel flow issue I would expect issues under all RPM's at heavy load.
1 Lucky Texan likes this.
Glennda5id is offline
post #16 of 19 (permalink) Old 04-09-2019, 10:40 PM
Car: 2004 Outback H6 3.0 LL Bean Edition
Yes, there was a technical service bulletin on the TPS on the 2001-2004 H6 cars. Part is not too crazy expensive, I paid around $130, if I remember correctly.
And, as the previous respondent said, these engines do not use a MAF (mass air flow) sensor, but a MAP sensor instead, which is mounted on the throttle body, and measures vacuum.
2004 Subaru Outback
LL Bean Edition
H6 3.0 AT
Ken2004LLBean is offline
post #17 of 19 (permalink) Old 05-15-2019, 09:43 AM Thread Starter
ok, haven't used the outback much lately but still annoyed with this stutter. right around 2,5k rpm it disappears. The TPS was checked by the mechanic so should be ok. Any way to test the MAP sensor?
post #18 of 19 (permalink) Old 05-15-2019, 10:32 AM
refresh all the ground connections. I remove all I can locate, wire-brush all the surfaces on eeach side of terminals and the bolt and body, reconnect and smear with dielectreic grease.
has the alternator ever been swapped? we're sometimes given the incorrect part number when buying rebuilt alternators. Check operating voltage.
do you use high octane fuel? our owners' manuals recommend it and there is a power reduction if we use lower octane.
post #19 of 19 (permalink) Old 05-16-2019, 09:17 AM Thread Starter
I can check the voltage while running, the mechanic had also checked the wiring to the ignition and didn't find anything.
Any way to check the MAP sensor?
'05 OBXT- 2 problems: Stutter and smoke wagoon Gen 3: 2005-2009 7 07-07-2016 08:10 PM
Stutter on acceleration imagineer Gen 2: 2000-2004 16 09-06-2014 10:15 PM
Stutter / hesatation off idle kcinco Gen 2: 2000-2004 5 01-13-2013 11:25 AM
The next fix for the stutter problem after ECM update? yoeddy20000 Problems & Maintenance 0 11-22-2006 12:08 PM
2005 OB XT 5MT Stutter shizumaat Problems & Maintenance 1 07-01-2004 02:27 PM
