'03 VDC 1/3/5 misfire - Page 2 - Subaru Outback - Subaru Outback Forums
 1Likes
post #11 of 16 (permalink) Old 03-26-2019, 12:06 PM
botenredwolf's Avatar
Car: 2010 Legacy 3.6R Limited
What about the cat on that bank?
Kenwood DMX7704S + iDataLink Maestro, Stock H/K speakers and amplifier, JL 12W6v3 HO Wedge, JL XD1000/5v2 adding some kick. (Not hooked up yet: Hertz Energy component speakers)
botenredwolf is offline
post #12 of 16 (permalink) Old 03-27-2019, 05:28 AM
Car: 2001 outback H6 3.0 VDC
am I correct in thinking all the badly firing cilinders are on one side of the engine? maybe the cables to the coils are bad, plugs are in oil or your cams skipped a link?
guntherrex is offline
post #13 of 16 (permalink) Old 03-27-2019, 07:12 AM
eagleeye's Avatar
here is the firing order. looking back at older threads shows the myriad of problems associated with misfires along one side of EZ30 engines. (fuel, spark,...head gaskets )
eagleeye is offline
post #14 of 16 (permalink) Old 03-27-2019, 07:14 AM Thread Starter
fcfordlord's Avatar
Originally Posted by idosubaru View Post
Given it's all 3 cylinders I'd be looking into timing and carbon build up.
Carbon build up - how much carbon did you see inside the valve covers? I'm not sure how to further test this.
Timing - again I'm not sure how to diagnose the chain/tensioner but maybe your scanner can read the cam sensor or other appropriate signals to tell chain operation.
Make sure all your grounds are good although in my experience they run perfectly fine with multiple disconnected grounds dangling/rusted/severed.
No carbon at all. Cleanest i have ever seen.
Grounds are good. All were cleaned and tested while it was apart.
It may end up being timing. Trying to get the oxygen sensors out to pressure test the cats, someone torqued them down pretty good.
2003 Outback H6 LLBean
1999 Legacy Outback SUS
fcfordlord is offline
post #15 of 16 (permalink) Old 03-27-2019, 11:27 AM
Lion-O's Avatar
Car: 2003 Subaru Outback L.L. Bean
My exhaust cam jumped a tooth and caused a 1,3,5 misfire (bank 1, passenger side, if I recall correctly). I was able to accurately diagnose it using a leakdown test. The compression test was a slight indicator, bank 1 had 140 psi avg and bank 2 had 155 psi avg (stone cold). During leakdown, I had 80% leakage out the exhaust at TDC, but only 3% about 15* past TDC (exhaust valves closing late). Luckily one tooth off on timing doesn't seem to cause a piston/valve collision event as these are interference engines. I find that it's much easier to get to the coil packs and spark plugs from underneath the car. Good luck!
1 Lucky Texan likes this.
Lion-O is offline
post #16 of 16 (permalink) Old 03-27-2019, 11:45 AM
vacuum or intake manifold leak when warm????
does it stumble or miss when idling? if so, maybe selectively feeding in some propane from a handheld unlit torch around the intake mani and vacuum lines would help ?
1 Lucky Texan is online now
VDC ECU . TC switch scalman Electrical & Electronics 2 05-10-2019 02:15 PM
Testing OBW AWD with VDC off-road capabilities scalman Offroad Tech 47 04-28-2019 04:04 PM
Gen 3 Transmission Questions - Engine Braking? kirkbrode Gen 3: 2005-2009 21 07-19-2015 08:06 PM
Spark plug arcing, intermittent misfire, recent timing belt work SnowBird Gen 3: 2005-2009 3 07-20-2014 08:26 AM
'01 H6 VDC misfire codes on 2, 4, 6; other lights botenredwolf Problems & Maintenance 101 05-28-2014 10:57 AM
