02 outback headlight issue - Page 2 - Subaru Outback - Subaru Outback Forums
 4Likes
post #11 of 22 (permalink) Old 04-13-2019, 03:49 PM
Model12's Avatar
Originally Posted by mprosco91 View Post
Sometimes it more cost effective to buy the 2 pack and replace both. Depends
Sent from my SM-G955U using Tapatalk
I also do this and keep the old extra one in the car for an emergency spare
OldBay likes this.
Model12 is offline
post #12 of 22 (permalink) Old 04-16-2019, 06:39 AM
Car: 2001 outback H6 3.0 VDC
I had a similar issue, turned out to be a faulty relay. In case the new bulb won't work
guntherrex is offline
post #13 of 22 (permalink) Old 04-16-2019, 07:04 AM Thread Starter
How did you know your relay was bad?
Thetwister007 is online now
post #14 of 22 (permalink) Old 04-16-2019, 07:48 AM
Feedback Score: 11 reviews
Not a relay.
The 2002 Outback has two relays associated with the headlights. One relay powers the headlight bulbs (i.e., low and high beam bulbs) on the left side, the other relay powers the two headlight bulbs on the right side. Consequently, if a relay is bad, both bulbs on one side that it powers will not work.
In the current case, both right side bulbs work, and on the left side the low beam works, so both relays are working.
plain OM is offline
post #15 of 22 (permalink) Old 04-16-2019, 01:11 PM Thread Starter
This is what mine had in it. Now I know why it never worked lol. Cant see a wattage on the label.
post #16 of 22 (permalink) Old 04-19-2019, 10:52 PM Thread Starter
Just discovered a werid quirk... I replaced the high beam bulb and now when when I start the car with the headlight switch in the OFF position they actually stay OFF until I turn the on via the turn signal lever. But after doing that and replacing the defective pigtail sockets and bulbs I still have no park lights via the turn signal lever
post #17 of 22 (permalink) Old 04-20-2019, 07:38 AM
What am I missing -- is this a problem, or just and introduction to . . .
With the ignition Off, if the separate Parking Lights switch on top of the steering column is flipped to On, do the exterior parking lights come on?
With the Parking Lights switch on top of the steering column is Off, the ignition is On, and the headlight switch is turned to either the first (parking lights) or second (headlights) position, do the interior lights for the dashboard controls (switches etc) come on, while the exterior parking lights still remain off?
plain OM is offline
post #18 of 22 (permalink) Old 04-20-2019, 09:35 AM Thread Starter
Yes to both of those questions. I thought replacing those things might of fixed the problem. That is what I meant by both statements.
post #19 of 22 (permalink) Old 04-20-2019, 11:11 AM
eagleeye's Avatar
DRL = low beam lights on low power.
high beams need to be turned on by twisting the stalk, and shoving it forward.
_______
parking lights, = the switch on top of the steering column, the only ones that work without the key (very hard to drain a battery on such a old subaru, as everything but these goes off with the key,... people hit this switch with sleaves, watches, etc. and then post here about why these lights don't go out, = "virgin switch threads" )
___
marker lights, = twisting the stalk one notch, these go off when you turn the key to off.
_____
most of the above is in the owners manual,
eagleeye is offline
post #20 of 22 (permalink) Old 04-20-2019, 01:25 PM
So, do I have this right? The exterior parking lights work when the separate Parking Lights switch is flipped to on, but when that switch is Off, the parking lights do not work when the headlight switch is turned to either the first or second "on" position, and in the latter case, even though the interior dashboard control lighting does work.
In that case, the most likely problem is the Parking Lights switch on top of the steering column. When it's Off, and the headlight switch is turned on, the power for the interior dashboard controls and the exterior parking lights comes from the tail & illumination relay. The power for the dashboard controls goes more or less directly to the control wiring, and because the controls light up, we know the relay works. But the power for the parking lights in this scenario goes through the "Parking Lights" switch on the steering column, even when it's Off!
The switch has two sets of contacts. On set is for when the ignition is off, and the Parking Lights switch is flipped to On to turn on the external parking lights. This we know works. The other set is closed when the switch is Off, and connects the power from the relay to the parking lights wiring harness. Because the parking lights wiring is good (because it's the same in all cases), and the relay works, about the only thing left is those "off" contacts in the Parking Lights switch. This has been seen before. Sometimes flipping the switch on and off repeatedly might restore the contact connections, but it's equally if not more likely the switch will have to be removed, and if the contacts cannot be exposed and refurbished, the switch will have to be replaced.
There's a small chance that the wire coming from the relay to the switch is bad. In one case the wire's connection to the switch had overheated, and the wire had separated from the switch, but that's an unusual situation.
plain OM is offline
Alignment specs Impreza Outback vs Legacy Outback issue Defiantpunk467 Wheels, Tires, Brakes, & Suspension 0 08-01-2017 06:30 PM
Consumer Report Outback ratings are out feuerwehr Gen 5: 2015-2019 58 04-08-2016 01:27 PM
Thanks and will miss my 2006 Subaru Outback XT imdakine1 General Discussions 6 08-19-2014 11:52 AM
'03 Outback Headlight Wiring Issue Ofphil Electrical & Electronics 0 12-02-2013 10:43 AM
98 outback headlight issue, new 3 prong pigtails, lights low power sirtef9 Electrical & Electronics 1 06-11-2012 11:18 AM
