transmission mount - H6 2003 - Subaru Outback - Subaru Outback Forums
 6Likes
post #1 of 47 (permalink) Old 04-16-2019, 03:55 PM Thread Starter
AudiA8's Avatar
Car: Audi A8, 2002 Outback
So I've installed a new tranny mount - the old one was indeed broken. While banging various hardware with a rubber mallet under the car the other day I notice how much play there was in the new mount.
I am wondering if I did not tighten the center bolt enough, I have posted photos of a screen grab of Mr Subaru via youtube and a photo my mount. Looks like the rubber washer on my mount is not flush with the surface of the mount.
I think I tightened it as much as I could ???? Could this be the source of my idle vibration - Did I get the wrong mount - it was OEM from subie and correct for year and model.
Name:	mr s 1.jpg
ID:	450039   Click image for larger version
Name:	mr s 3.jpg
ID:	450041   Click image for larger version
AudiA8 is offline
post #2 of 47 (permalink) Old 04-16-2019, 04:01 PM Thread Starter
AudiA8's Avatar
Ok just looked at https://www.oempartsinc.com/oem-part...g2LWdhcw%3D%3D
WTH is Trans Cross-Member Stopper - Subaru (41022AE19A)!!!
Looks like I have it but why the big gap!! One would think it should be flush with the cross member ?
AudiA8 is offline
post #3 of 47 (permalink) Old 04-16-2019, 05:32 PM
Feedback Score: 11 reviews
Looks similar to mine. I had the same question some time ago: https://www.subaruoutback.org/forums...2007-4eat.html
plain OM is online now
post #4 of 47 (permalink) Old 04-17-2019, 12:22 AM Thread Starter
AudiA8's Avatar
Yes I just realized that it seemed to be normal. I still have quite a bit of movement if I put a pry bar on cross member so perhaps I have worn engine mounts too. Just that dam vibration at idle - some guy sells an insert where this bolt goes to supposedly reduce the vibration but its hard to believe that Subaru would design the engine to vibrate like this.
AudiA8 is offline
post #5 of 47 (permalink) Old 04-17-2019, 10:41 AM
Car: OBW H6 VDC, Tribeca, XT6
your hunch is correct, they don't do that off the showroom floor.
idosubaru is offline
post #6 of 47 (permalink) Old 04-18-2019, 04:15 PM
cardoc's Avatar
Did you install a good trans mount? The center bushing should bottom out on the transmission cradle. If not, then the bolt is too long or the mount is too narrow when compared with a correct sized mount.
cardoc is offline
post #7 of 47 (permalink) Old 04-18-2019, 04:56 PM
Do you mean that castle-nut looking washer should be up against the crossmember?
I thought there should be a gap. That's the way it is on mine, and I thought it was confirmed in this post. Did I misunderstand, or perhaps the 2003 H6 is different.
(Of course, the gap in the OP's case, might be too large . . .)
post #8 of 47 (permalink) Old 04-19-2019, 04:45 PM
cardoc's Avatar
Subaru used the same transmission mount for the 4EAT and 5EAT transmissions. Every one I've put in, that rubber/metal bushing rest against the cradle when the center nut is tightened. When there's a gap, that's when you know the mount is weak because the compressed rubber allows for the center bolt to drop further through the cradle.
cardoc is offline
post #9 of 47 (permalink) Old 04-19-2019, 05:16 PM
Do you mean the bushing should be resting up (snug against) the rear crossmember in the attached diagram? Wouldn't that restrict, if not totally prevent, movement of the transmission tail section?
I don't recall seeing any of those bushings up against the crossmember, but I'll have to look more closely now.
Name:	tranny mount.jpg
post #10 of 47 (permalink) Old 04-19-2019, 05:17 PM
traildogck's Avatar
Car: 2005 XT, Mildly Modified...2006 XT Limited, Highly Modifed
I have to disagree. Only because I now make transmission inserts for every automatic transmission (and some manuals) for every Subaru produced world wide since 1992. There are 5 differnt void shapes for all ATs (including all CVT) and 1 that is specific to the 6MT diesel.
The design of the mount is the same. The cushions and the size of the void are different. The 4EAT void is wider that the 5EAT.
The center bolt is a safety bolt to limit the movement. It acts as a stop.
tdck's FrankenWagon
suspension - brakes - cooling - power
XRT Tuned, Running Blind
tdck's Cherry Bomb
Chassis & Suspension Bits
Also XRT Tuned & Running Blind
CKE SSP product information and sales :
traildogck is online now
2003 outback auto transmission Drsuds Parts, Accessories, & Performance 0 04-02-2019 11:00 AM
Transmission Valve Body and Transmission Control Module awitt Problems & Maintenance 8 11-23-2015 06:45 PM
2003 Outback H6 Auto Transmission Question gergg Gen 2: 2000-2004 12 03-29-2012 01:17 PM
2003 manual transmission fluid type adisb General Discussions 3 09-18-2011 07:31 PM
5MT/6MT Bushing Kits, Short Shifters, 4EAT/5EAT Trans Mount Inserts... RalliTEK.com Vendors' Playground & Reviews 11 01-06-2009 08:30 PM
