Trying to save 01 Outback - Engine and Tranny Swap - Subaru Outback - Subaru Outback Forums
 1Likes
  • 1 Post By MikeC5
post #1 of 4 (permalink) Old 05-13-2019, 04:59 PM Thread Starter
Hello, I'm really jumping in head first here, this is my first post so please bare with me.
I have been researching for about 2 months on this and I have had multiple shops give me conflicting information, I myself have found conflicting information online, so of course, I turn to the forums (and for the record, I have scoured the forums in search of these answers already). All I am hoping for is some sort of a consensus, not looking for perfection. Ideally someone has done this before (fingers crossed).
I have a 2001 Outback that blew a motor and transmission due to a botched head gasket job and botched transmission rebuild. You definitely get what you pay for (I had a private guy do it, friend of a friend kinda deal due to my financial situation at the time). The rest of the car is in fantastic condition and I would love to save it.
I also have a 2008 Forester X that I bought stupid cheap (to drive on an emergency basis after I lost the 01). Basically, that car is a metal deathtrap due to rust, however, the engine and transmission seems to be in perfectly fine condition.
Now that I can afford to properly address them, I want to know if it is possible to swap the 2008 Forester engine and transmission into the 2001 Outback.
The placard inside the engine bay for the Forester is missing, but this is what I know for both cars.
2001 Outback Engine: EJ251AXAWL
2001 Outback Transmission: TZ1A4ZCCBA
2001 Outback VIN# 4S3BH686X17638942
2008 Forester Engine: EJ25
2008 Forester Transmission: M000T20171
2008 Forester VIN# JF1SG63618H732695
Thanks all for the help, I've hit roadblock after roadblock trying to figure this out and this is basically my last move.
Mccoydt is offline
post #2 of 4 (permalink) Old 05-16-2019, 10:27 AM
Car: 2002 Outback
After a bit of research, it appears the swap you propose is possible although I'm not that familiar with 2008 models. If I were doing it, I would keep the intake manifold, fuel injectors, sensors, etc. from the '01 OB and use on the new long block from the Forester. This should get you past most of the differences in mass air flow, etc. I'm sure the '08 engine has more going on in terms of oxygen sensors and how many/where the cat converters are. But I would expect the '01 exhaust (including Y-pipe) would bolt right up to the '08 block without any issues. I would expect the transmission, as long as it is a 4EAT, will still work but you may want to look close at the electrical connectors and make sure they are the same and can plug into the existing '01 harness. You might also try asking over at NASIOC as they seem to do a lot of engine swapping over there. I found this summary of EJ 2.5 L engines on Wiki that may be useful. https://en.wikipedia.org/wiki/Subaru_EJ_engine#EJ25
BiggFella Tilghman likes this.
MikeC5 is online now
post #3 of 4 (permalink) Old 05-17-2019, 10:19 AM
BiggFella Tilghman's Avatar
Car: 2002 Outback 2.5
Appreciate that wiki link
Sent from my SM-N960U using Tapatalk
BiggFella Tilghman is offline
post #4 of 4 (permalink) Old 05-19-2019, 11:02 AM
The newer motor will have some variable valve adjustments that the older one in your 01 won't have. It might still work just without the ability to use different cam profiles based on RPM, For transmission you may need to grab the rear diff from the forster as well, the final drive may be different and mixing transes and diffs with different final drives could lead to some issues with the center diff.
Nitro350Z is offline
1998 Legacy Outback - Engine swap Options ccbweber Problems & Maintenance 3 11-01-2018 03:59 PM
2002 outback engine swap Mohammada Parts, Accessories, & Performance 1 04-01-2018 01:03 PM
Can I swap my Outback 2000 EJ25 engine automatic with Forester 2000 L EJ25 manual AR2300 New Member/User? Look Here! 3 07-17-2017 04:28 PM
1999 legacy outback Phase 2 engine, phase 1 tranny swap? tunzuhphun General Discussions 5 01-24-2016 07:41 AM
1996 Legacy Outback engine swap issue SnowHill11 Gen 1: 1995-1999 1 09-26-2012 05:50 PM
