Broken Timing Belt - Subaru Outback - Subaru Outback Forums
 5Likes
post #1 of 17 (permalink) Old 03-04-2019, 10:54 AM Thread Starter
Jon98EJ25's Avatar
Broken Timing Belt
Hi everyone,
Last night I went out to start my '98 OBW with the 2.5L and I believe the timing belt broke. It started cranking unevenly without starting. Sounds like it's only getting compression on 2/4 cylinders.
I'm annoyed because the PO told me this was replaced about a year ago or so. I did notice soon after buying the car there was a loud "whirring" sound in the front of it. I wondered to myself if the t-belt was installed improperly. Guess I got my answer.
Anyway, I'm getting a lot of conflicting information looking around on the internet whether or not this is an interference engine.
From what I gather, it sounds like there's no piston to valve interference, but there is the potential for valve to valve interference. Is this correct? Should I bother trying to replace the timing set, or are the valves certainly damaged?
The one thing I have going for me is, this happened while starting not while running in gear etc. Also, I didn't hear or feel any impact and the engine was cranking freely without obstruction as far as I could tell.
Is it also possible it jumped some teeth or something?
Thanks in advance for any and all advice.
-Jonathan
-Jonathan
1998 Subaru Outback
2.5L 5SPD
Jon98EJ25 is offline
post #2 of 17 (permalink) Old 03-04-2019, 11:12 AM
Car: 2006 2.5i and 2002 3.0 wagons.
It's an interference engine. If the belt broke or jumped many teeth, valves and pistons typically get really acquainted with each other.
Have you considered the Google search bar at the top of the forum?
Ours:
2002 Outback wagon 3.0 L.L. Bean no more: "Mal" 136,000 and counting.
Cloth interior swap. HIR1 high beam upgrade.
2006 Outback 2.5i wagon: "Professor Sprout" 97,000 and counting.
Family fleet:
2006 Outback XT Limited. 109,000 and bone stock.
Previous:
1996 Outback wagon "Solstice", totaled at 115,000.
2003 Outback wagon"Kaylee", sold at 167,000.
AWDFTW is offline
post #3 of 17 (permalink) Old 03-04-2019, 11:17 AM Thread Starter
Jon98EJ25's Avatar
Ah darn. Okay thanks.
-Jonathan
1998 Subaru Outback
2.5L 5SPD
post #4 of 17 (permalink) Old 03-04-2019, 11:56 AM
Performance Suby's Avatar
Car: 2003 OBW 2.5L 4EAT
If you end up repairing the car, make sure to install a timing belt kit with all idler pulleys, tensioner and water pump. Sometimes people tend to not replace all of the components and then down the road issues arise, from part failure.
'03 Outback 2.5L 4cyl w/all-weather 4EAT
'06 Forester 2.5L 4cyl X Premium 4EAT
'05 Impreza 2.5L 4cyl RS Sport 5MT (current daily driver)
Performance Suby is offline
post #5 of 17 (permalink) Old 03-04-2019, 12:04 PM Thread Starter
Jon98EJ25's Avatar
Yeah. Right now I'm trying to decide if I want to potentially buy heads for this car. I need to figure out if I want to just try the timing set first and maybe spend the money for nothing. I really like the car and would like to keep it, but I'm looking at probably $1,000 even at DIY prices. Kinda sucks.
I could pull the motor out and take the heads off to see what's going on, but I really like the idea of changing the timing set and having it fix the problem without all the extra work. This is my commuter so I need to have it up and running again as soon as possible.
Would it be a bad idea to just replace the valves if there's damage, or do the cam(s) usually get damaged as well? Is it better to just get new heads?
-Jonathan
1998 Subaru Outback
2.5L 5SPD
post #6 of 17 (permalink) Old 03-04-2019, 01:47 PM
pull the covers and inspect the timing. find the tooth-count for the engine online, roatae by hande and count the teeth, very slight possibility you're off JUST enough teeth to not start, not enough to clash with pistons. That would be lucky. Often, belts are OK but the toothed idler fails.
how many miles on engine? if high - one approach might be to get a used engine, put MLS head gaskets and new timing parts on it and swap in. fewer miles and more reliability.
1 Lucky Texan is online now
post #7 of 17 (permalink) Old 03-04-2019, 06:22 PM Thread Starter
Jon98EJ25's Avatar
Texan, the car has about 151,000 on it. Not sure to what extent the timing set was serviced before. Maybe they didn't change everything out. I'm going to jump in there today and take a look. The fun part today will be trying to get the car out of the side-driveway, out on to my steep hill, turned around and back in the drive way. Might have to use the starter. Yeesh.
Thanks for the help!
post #8 of 17 (permalink) Old 03-04-2019, 06:29 PM
Most likely tensioner failed, and it jump a few teeth. You might be okay. Good luck!
miker104 likes this.
tdelker1 is offline
post #9 of 17 (permalink) Old 03-04-2019, 06:49 PM
AA8LL's Avatar
Car: 2017 Outback Limited 3.6 CVT, EyeSight+SRVD, 2-fob Subaru remote start
All that maneuvering on the starter will probably finish off both the timing belt and the starter. I suggest you use a wrecker.
1 Lucky Texan and Tishers like this.
AA8LL is offline
post #10 of 17 (permalink) Old 03-04-2019, 07:32 PM
Wiscoutback87's Avatar
Car: 2014 Subaru Outback 2.5 Premium
I was thinking the same thing, if timing is your goal a used engine swap might be the quickest route to take.
2014 Subaru Outback Premium 2.5
Wiscoutback87 is offline
TD garage Berkeley Kidrock Gen 3: 2005-2009 2 10-14-2016 12:57 AM
Timing Belt Change mikec Problems & Maintenance 0 06-01-2013 02:20 PM
Timing belt tensioner bolt broken datski Problems & Maintenance 2 05-29-2013 11:02 PM
Choice of a timing belt kit eugenelt Problems & Maintenance 12 01-08-2012 04:13 PM
Broken Timing Belt rbutcher Problems & Maintenance 49 12-30-2010 01:51 PM
