Mods and DIY Organized List - Page 53 - Subaru Outback - Subaru Outback Forums
 493Likes
LinkBack Thread Tools Rating: Thread Rating: 14 votes, 3.00 average.
post #521 of 534 (permalink) Unread 10-03-2018, 02:12 PM
Dantrax's Avatar
Car: 2018 White Outback Touring 2.5i
I tried to keep the cutout as small as possible & filled it in with part of the cut-out piece & black silicone & Gorilla tape. I was going to try to add another piece of plastic underneath by drilling 3 holes and using push pins to hold that piece in place. But that pushpin under the gorilla tape is on an angled piece of plastic so I'm not sure that will work. I'll play this weekend.
ID:	438135   Click image for larger version
ID:	438137   Click image for larger version
ID:	438139   Click image for larger version
ID:	438141   Click image for larger version
ID:	438145   Click image for larger version
r3ds4nd likes this.
Dantrax is offline
post #522 of 534 (permalink) Unread 10-11-2018, 01:37 PM
Dantrax's Avatar
I overpaid AutoZone for a pair of Super Bright LED 921 6000k bulbs. They seem brighter in the daytime so I hope they brighten things up tomorrow morning when I back out. When I step on the brakes while reversing I can see when I'm backing out. Now I know there are 3 brake lights but the old reverse bulbs are pretty weak. I hope these will be much better when reversing for the price. The bulbs are stake on so they just slide into place. The holder is a 1/4 twist and pull it out. When you put it back in there is one larger slot you have to line up with the thicker tab.
ID:	438625   Click image for larger version
ID:	438627   Click image for larger version
ID:	438629   Click image for larger version
ID:	438631   Click image for larger version
r3ds4nd and shkish like this.
Dantrax is offline
post #523 of 534 (permalink) Unread 10-11-2018, 01:45 PM
Dantrax's Avatar
I forgot the picture I took today in the rain in front of a store window.
Name:	20181011_112957 - Copy.jpg
JennRosa and shkish like this.
Dantrax is offline
post #524 of 534 (permalink) Unread 10-13-2018, 09:05 AM
Dantrax's Avatar
Well the new bulbs are much brighter than the old ones. It is harder to see the additional light difference when stepping on the brakes. So I guess it is worth it safety wise but I wish Wally world had them for 1/2 the price just saying.
shkish likes this.
Dantrax is offline
post #525 of 534 (permalink) Unread 10-20-2018, 12:25 PM
Dantrax's Avatar
I finally took some pictures of the cup cover dmarsh15 found. It's a pretty good match of the panel not 100% but pretty close.
ID:	439121   Click image for larger version
ID:	439123   Click image for larger version
Dantrax is offline
post #526 of 534 (permalink) Unread 04-06-2019, 12:20 AM
Skemcin's Avatar
Car: 2015 Subaru Outback Premium | 2007 Outback 2.5i
Universal License Plate Antenna Mount in my 2016 Outback Premium
https://www.gorillaoffroadcompany.co...nt=31848470028
ID:	449241   Click image for larger version
ID:	449243   Click image for larger version
Dantrax likes this.
- 235/70-16 Cooper Discoverer AT3 (soon)
- License Plate Antenna Mount w/4' Firestik
2007 Subaru Outback 2.5i
- Gorilla Offroad Bar w/skid plate and winch mount
- Superwinch Terra 45 Winch
- 2 2.5in LED Daytime Running Lights
- 4 55w HID spot lights
- 1 2.5in LED roof mounted / rear facing
- LGT Brake Upgrade
- 1in Lift Spacers
- 04 OB Rear Struts
- 235/60-17 Cooper Discoverer AT3
Skemcin is offline
post #527 of 534 (permalink) Unread 04-13-2019, 08:12 PM
Dantrax's Avatar
I put the cigarette lighter in today. The cigarette lighter directions say they're for 2015-2019. They show the 2017 HVAC panel with 3 knobs and how to remove that one. But I couldn't figure out how to get the 2018 HVAC panel out of the way using the directions. So I didn't move it. The rest of the directions seemed accurate so I was able to get the rest of the center console apart. But to put the lighter in I had to fight & bend the top corners of the flip-lid center console storage cup to get it out from under the HVAC panel. I did manage to get it out and install the lighter into it without breaking anything but it was a PITA. I have to admit I was sweating it for a while. Anyway it's in and done but it might have been easier to get her to quit smoking. Nah
Dantrax is offline
post #528 of 534 (permalink) Unread 04-15-2019, 07:20 AM
Car: 2015 Outback 3.6
Dantrax where I’d you find the directions to remove the flip-lid center storage?
Yetimai is offline
post #529 of 534 (permalink) Unread 04-15-2019, 12:52 PM
Dantrax's Avatar
https://subaruonlineparts.com/subaru...er-p-3737.html Click on view installation instructions:here Or this https://subaruonlineparts.com/docs/H6710AL010.pdf Warning this doesn't tell you how to get the flip-lid center storage out from under the newer 2 knob HVAC panel. I had to chance breaking the flip-lid center storage to bend it out from under the HVAC panel. The center big storage box has 4 screws. 2 are under the cup holder cover & the other 2 are behind small oval covers just above the driver & passenger seat cushions. They're a little tricky to find.
Dantrax is offline
post #530 of 534 (permalink) Unread 04-16-2019, 10:46 PM
Car: 2019 Outback 25i Limited
Just installed non-OEM splash guards today. Purchased one set from Ebay.
https://www.ebay.com/itm/Fits-Subaru...72.m2749.l2649
Overall, 100% satisfied. They fit perfectly and all the hardwares work as intended. For the rear ones, use 8mm socket and small ratcheting wrench to fasten the screws.
ID:	450069   Click image for larger version
ID:	450071   Click image for larger version
ID:	450073   Click image for larger version
sulsj is offline
