Gen5: Replacing the original battery with BETTER - Page 78 - Subaru Outback - Subaru Outback Forums
 452Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 4.00 average.
post #771 of 794 (permalink) Old 04-15-2019, 08:53 AM
Fibber2's Avatar
Originally Posted by 10SCJed View Post
.......... I had a rat in the serpentine belt all wrapped up and had thrown off the belt. After prying him and the belt off I went on the quest to replace the belt as it had been compromised by being thrown. Tough to find the belt-nobody has them-even Subaru as the car was so new. The dealer asked why I was replacing it and how many miles were on the car? I just showed him the pictures.
Your story sort of reminds me of when I had my woodworking shop in the barn/garage while we were restoring an 1880's farmhouse. I hadn't used the 12" two wheel band saw in a few weeks, and apparently a family of mice thought it would be great to build a nest in the upper wheel. Can you picture the scene when I placed a nice piece of wood on the table and turned the darn thing on? Yes, hot and cold running mice parts! After my shower and a day of cleaning, all was right again.... yuk
Fibber2 is offline
post #772 of 794 (permalink) Old 04-16-2019, 02:24 PM
10SCJed's Avatar
Car: 2018 3.6R Limited with #2 package in Crystal White Pearl
Shredded mouse-it's whats for breakfast.
May the Four Winds Blow You Safely Home
10SCJed is offline
post #773 of 794 (permalink) Old 04-16-2019, 11:36 PM
Danver's Avatar
This post would probably fit better somewhere else but since it is a continuation of my hard-wired battery maintainer plug I will just put it here.
Since I already had this convenient little fused power source/maintainer connection that only be used on rare occasions I plug in my battery maintainer I decided to find a secondary use for it.
Originally Posted by Danver View Post
I sometimes wish there was an underhood light that came on automatically when the hood is opened, so I added one using my maintainer plug as the power source. When I want to use the maintainer I will just have to unplug the light.
For the light to come on automatically I used a spring loaded switch and made a bracket out of aluminum to mount it. When the hood is opened it completes the circuit and the two LED lights I mounted to the underside of the hood come on.
The way it is set right now the lights come on when I pop the latch and the hood is still on the safety latch. I think I am fine with that but might adjust it later so the lights don't come on until the hood is opened past the safety latch.
Installing this during the day I had no idea if the two lights would be enough or if the location would work well. I figured I could add another light or two towards the back of the hood if needed, but when I tested it after dark there was plenty of light.
For this test run I just twisted some wire connections together so I need to go back and shorten up a couple of wires and do some proper connections, but so far I like the results. I unplugged everything when I was done until the wiring is done correctly.
ID:	450077   Click image for larger version
ID:	450079   Click image for larger version
ID:	450081   Click image for larger version
ID:	450083   Click image for larger version
Danver is offline
post #774 of 794 (permalink) Old 04-17-2019, 09:35 AM
Car: 2017 Outback
I like your lights,good idea
Danver likes this.
Ravenworks is offline
post #775 of 794 (permalink) Old 04-17-2019, 02:09 PM
Car: 2010 Outback Premium 2.5i
Lighting up the engine compartment looks like my next project....
Danver likes this.
markjs is offline
post #776 of 794 (permalink) Old 04-17-2019, 08:35 PM
jakemccoy's Avatar
Car: 2018 Outback 2.5i Limited, No Eyesight, No Navigation
With a Fumoto valve installed, you could do a full oil engine in the pitch dark without any tools.
jakemccoy is online now
post #777 of 794 (permalink) Old 04-17-2019, 08:39 PM
ELCID86's Avatar
Car: 2018 OB Limited 2.5
Danver likes this.
Shawn in VA (USA)
ELCID86 is offline
post #778 of 794 (permalink) Old 04-17-2019, 11:44 PM
Danver's Avatar
One more function for my multi-purpose accessory underhood wiring harness. This one more of a "just because I can" than something I really need.
This cigarette-lighter style socket has the same connector as the battery maintainers so I can plug this in to use accessories that would plug into a cigarette lighter.
I recently put new wires and switch in my vintage 1970's or 1980s era handheld spotlight that I have had since I was in high school. That 40-year-old halogen bulb has definitely lost some of its brightness from back in the day but amazingly it still works.
A small air pump could probably be plugged into it but the one I have is rated at 20 amps and has alligator clips so it gets hooked directly to the battery terminals anyway. I can't think of anything else I currently have that I could use the accessory plug for.
ID:	450163   Click image for larger version
Danver is offline
post #779 of 794 (permalink) Old 04-18-2019, 12:56 AM
Car: 85BRAT97SVX03Baja5mtHonda's
fialed bnattery owners please log you NHTSA issues here...
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
i think that is the link. please dont fail to complain. it only makes these problems go away/.....
85BRAT 97SVX, 2x91 Honda CRX, 91 RT4wd
03Baja
bheinen74 is offline
post #780 of 794 (permalink) Old 04-21-2019, 08:38 AM
Deep Cycle Battery
My son needed a new battery in his '13. I had an almost new large Deep Cycle Marine Battery on hand, so we gave it a try. It was a tight fit and has been working great for that last 3 months.
ID:	450361   Click image for larger version
bmoreted is offline
