Replacing horns with Sharptones -- Dr side not PnP? - Subaru Outback - Subaru Outback Forums
 9Likes
post #1 of 20 (permalink) Old 09-05-2018, 10:43 PM Thread Starter
Marc Hufnagel's Avatar
Found a set of the Hella Sharptones and received them today. They have two spade plugs on them (not marked -/+.
Looking at a PDF it shows what appears to be a heatsink and a warning that 'resistor may become hot'
Has it moved to horns now are special and can't just be swapped out?
I saw the grimmspeed harness but apparently it isn't for an 18 OB, nor is subimods. I really don't want to go cutting wires and that possible inline resistor bothers me now.
2018 Subaru Outback Touring 3.6R - Crystal White - Whole bunch of Accessories.
Marc Hufnagel is online now
post #2 of 20 (permalink) Old 09-06-2018, 10:32 AM
Car: 2018 Outback Limited 2.5i
First off, polarity for horns doesn't matter, so you can hook it up either way around.
Second, I checked an online parts fiche, and it appears that Subaru used the same low tone horn since basically forever, and the same high-tone horn from 2015-current. It also looks like the parts fiche indicates that the low-tone horn is on the driver's side.
I don't know about Subaru's and Outbacks specifically, but typically there are two different methods that I've seen horns use. The first is a single spade connector on the OEM horn that carries the positive voltage, and then it grounds through the vehicle body (this looks to be what the Grimspeed harness is set up for). The other is a two-pin connector, usually something like a metripack or something similar. If this is what's on the car, your best bet if you want to avoid cutting is to purchase a matching plug, and make your own harness.
If you can provide a picture of the connectors on the horn, I may be able to identify the connector and give you a course of action; I'm at work and don't have my car with me. From some online parts photos, it looks like they may be a single spade terminal connector, but sometimes they use a generic photo.
Finally, what PDF are you looking at?
1 Lucky Texan and SmokeyBear like this.
abbarach is offline
post #3 of 20 (permalink) Old 09-06-2018, 12:58 PM Thread Starter
Step 5 on this pdf What would this 'resistor' be that could get hot? The connector on the driver side is not the spade connector but some block sort.
post #4 of 20 (permalink) Old 09-10-2018, 07:10 AM
KYBubblehead's Avatar
Car: '16 Outback 2.5i Limited - Eyesight
Send a message via MSN to KYBubblehead
I took off the bumper cover and replaced both horns with the same kind (Hella Sharptone). As they are used infrequently, I don't ever see there being a heat problem. A very easy switch; certainly louder than the wimpy factory horns...
FTCS(SS) USN Ret.
'16 Outback 2.5i Limited w/Eyesight
'06 GL1800 Gold Wing Motor Trike w/2008 Lees-ure Lite
'18 Honda Civic Hatch Sport Touring
KYBubblehead is offline
post #5 of 20 (permalink) Old 09-10-2018, 09:52 AM
OK, so the manual does show a different connector on the driver's side, but it looks like it's still a single-terminal connector, so you may be able to get a spade connector in there and hooked up to it. I'm guessing it may just be because they run a jumper wire from that connector over to the passenger side, so they needed a different connector to be able to have two wires connect to the same terminal.
I'm guessing that the resistor is the rectangular device mounted slightly up and left of the horn on the driver's side. The drawing makes it look like it has cooling fins, which would make sense for a resistor. It doesn't look like it has anything to do with the horn, to me (as it has a multi-terminal connector on it). It's most likely associated with sinking power for some other system on the car, and they just put it up there where it can get some air-flow to help cool it off. I wouldn't worry about it at all, beyond just trying not to touch it if you have had the car running recently.
If you're mounting your horns together, you can always use the "high" horn connector to get your positive power for both horns. If you're keeping them in the stock locations, then you'll need to have a look at the connector on the "low" side and see what you can do to get a terminal on it. My guess is that you should still be able to hook it onto a spade terminal on the new horn, or make up a small jumper wire with a female spade on both ends... one end goes in the connector, the other on the horn, if the extra bulk of the connector would make it too difficult to get a connector on the ground terminal. Either way, I don't think you're going to have much difficulty...
abbarach is offline
post #6 of 20 (permalink) Old 09-10-2018, 10:40 PM Thread Starter
I plan on checking these locations out tomorrow evening if I can get the chance. I do plan on leaving them in the stock locations.
post #7 of 20 (permalink) Old 09-10-2018, 10:41 PM Thread Starter
I'll try to get pics in the next day or so, and would welcome your thoughts. thanks
post #8 of 20 (permalink) Old 04-15-2019, 03:08 PM
Did you ever get your horns installed? Or pictures of the OEM horn harness...spade or 2 pin?
lac302 is offline
post #9 of 20 (permalink) Old 04-15-2019, 03:54 PM
Brucey's Avatar
Car: '17 3.6 Limited
If you can wait a bit I just won a set of these and guess I'll make an install video specific to the Outback.
Brucey is online now
post #10 of 20 (permalink) Old 04-15-2019, 03:57 PM
Car: 19 Outback 3.6r Touring, 12 Forester X, 09 G8 GXP, 08 BMW 535xi
Real MVP !
Cant’ wait !
SmokeyBear is offline
