2018 2.5 uneven acceleration - Subaru Outback - Subaru Outback Forums
post #1 of 10 (permalink) Old 09-25-2018, 05:56 PM Thread Starter
Tbirdhs's Avatar
Car: 2018 2.5 premium.
After driving Prius's for over ten years I have a very light foot on acceleration. My car has a surging, hesitation taking off from a stop till about 25mph. It is very un-even and seems to be getting worse. Brought it in after 8 months and 2k miles of driving for its first oil change and checkup. That was my only complaint. The dealer stated tech drove the car and felt nothing and no codes were found and no updates. Anyone else have this issue??
Fun Fun Fun till Daddy takes the Tbird away
Tbirdhs is offline
post #2 of 10 (permalink) Old 09-25-2018, 06:14 PM
Car: Sometime in December 2019 Crimson 3.6R Limited 2010 Murano SL, 2008 Mazda MX5
Recently test drove the 19 2.5 and had this same feeling - there are threads dealing with this on the site. some answers and some uncertainty. Made up my mind on a different engine.
Billiebad is offline
post #3 of 10 (permalink) Old 09-25-2018, 06:18 PM
brucep's Avatar
I have been seeing the VERY SAME complaint over in the IMPREZA5 forums. The surging seems to be more prevalent just after starting cold engine.
brucep is offline
post #4 of 10 (permalink) Old 09-26-2018, 12:00 AM
Car: 2017 Outback 3.6R Limited
That's just the way the CVT is programmed. You can make acceleration more smooth by pressing the "X-mode" button, unfortunately this mode only meant to work at slow speeds.
Alexus is offline
post #5 of 10 (permalink) Old 09-26-2018, 06:21 AM
My 18’ 3.6 does it as well.
It’s been to the dealer once. They said no problem found, no updates. I’m almost at 5k miles. I told the dealer I’d drive it till 5k to try and have the trans learn. But it seems to be no change so far. My wife drives it so I don’t get to feel it every day. Doesn’t seem to bother her. 🤔
It’s really bad when cold. When warmed up it happens a lot but not every time. I’ve used manual mode several times and it seems to not happen at all. I’ve come to the conclusion it is the torque converter and an early 1-2 “shift” that causes it.
1-2 fake shift happens at 10-12mph, that’s right when it starts. Then probably again on the 2-3 shift at 20 mph.
I’ll probably take it in again soon and have them reset the trans to relearn, and check for updates.
bmobuell is offline
post #6 of 10 (permalink) Old 09-26-2018, 06:46 AM
Yoda_One's Avatar
Car: 2015 Legacy 3.6R ES, 2014 Forester Touring ES, 2005 Jeep Liberty Limited
Originally Posted by bmobuell View Post
My 18í 3.6 does it as well.
Itís been to the dealer once. They said no problem found, no updates. Iím almost at 5k miles. I told the dealer Iíd drive it till 5k to try and have the trans learn. But it seems to be no change so far. My wife drives it so I donít get to feel it every day. Doesnít seem to bother her.
Itís really bad when cold. When warmed up it happens a lot but not every time. Iíve used manual mode several times and it seems to not happen at all. Iíve come to the conclusion it is the torque converter and an early 1-2 ďshiftĒ that causes it.
1-2 fake shift happens at 10-12mph, thatís right when it starts. Then probably again on the 2-3 shift at 20 mph.
Iíll probably take it in again soon and have them reset the trans to relearn, and check for updates.
When at a dead stop, just let off the brake and give it a moment 1/2 second to roll then ease on the gas this will eliminate this issue. Since you do not drive it all the time you haven't learn the car's idiosyncrasies.
It does take getting use to but once accustomed to it's behavior all is good. The 2.5i is more pronounce than 3.6 especially if it not at operating temperature.
Laughing at oneself and with others is good for the soul.
Yoda_One is online now
post #7 of 10 (permalink) Old 09-26-2018, 07:26 AM
I’ll try that ....thx
bmobuell is offline
post #8 of 10 (permalink) Old 09-26-2018, 07:50 AM
Car: 2016 WRX, 2017 BRZ, 2017 Legacy
My 2017 2.5i Legacy does it too, but oh so slightly that it's almost unnoticeable. I've chalked it up to the CVT, and have noticed it on other brand's CVT's as well (I rent cars a lot).
But now that I think about it, it could be the ultra-lean EPA fuel trims. Our 2005 OBXTMT did it a little too until we reflashed the ECU with an AP, which improved it. Same thing with my Ninja 1000 ... reflashed the ECU and the problem went away.
Hm. That's not likely going to be something Subaru is going to fix ... when out 2005 OBXT was doing it @ 30k, it took three trips to the dealer to get them to acknowledge it was doing it. Then they spent three days trying to figure it out before telling me "they all do that and it's just the way it is". Now, with 175k and post-burnt-valves, and a stage 1 tune, it still does it a little.
Maybe I need to look at as "just a Subaru thing", like the ill-fitting body panels and drunken-monkey-head-unit design.
Norskie is offline
post #9 of 10 (permalink) Old 09-26-2018, 09:35 AM
p12
p12's Avatar
Car: 2018 2.5i Premium - No Eyesight (and proud of it)
Between 2000 and 2300 rpm during slow acceleration, I feel a very slight amount of surging sort of like the transmission is trying to decide what to do.
If I keep it under 2000 rpm slow acceleration it is very smooth.
Above 2300 rpm slow to moderate acceleration it is smooth and responsive.
Hard acceleration above 2500rpm the CVT acts like a regular transmission with discernible positive shifts.
I'm beginning to think this is just the way the CVT is designed.
p12 is offline
post #10 of 10 (permalink) Old 09-26-2018, 07:04 PM
Car: '15 OB 3.6 Limited - Tungsten Metallic
owned two '15 3.6's and recently drove a '19 2.5 for an extended period. all have the uneven acceleration you mentioned. had a '19 Crosstek for an extended period and wow this powertrain was actually enjoyable. I'm not sure if its due to a new CVT or just a weaker engine/CVT pairing on the Crosstek but I would recommend that car over an outback until the '20 is introduced... even with the smaller size just put a roof rack/box on it.
todi1007 is offline
