Almost got killed today when the CVT cut out. - Page 5 - Subaru Outback - Subaru Outback Forums
 35Likes
post #41 of 60 (permalink) Old 02-10-2019, 09:50 AM
Originally Posted by GBMaryland View Post
They called my while I was out with my son (in the loaner car). Well, as I suspected: No codes and no indication of something wrong.
Crap.
Bummer. This is what dealers are coming to these days, they only want the easy money and have no clue how to figure out what's going on unless there us a part broke in two or a code set. I hope they are able to get on the horn with tech support and figure it out. Otherwise, I hope you have a lemon law option instead of taking it in the wallet for a trade.
dat2109 is offline
post #42 of 60 (permalink) Old 02-10-2019, 10:44 AM
atc98092's Avatar
How is it the dealer's fault if there's no codes and no indication of a problem? You want them to tear into the transmission on the off chance they might find something? With today's cars, that sort of repair attempts are impractical. Depending on the part (such as the CVT), dealers may not have the specialized tools and training to dive deep into it.
I'm not saying some dealerships aren't lazy, but to begin troubleshooting you have to have somewhere to start. I wouldn't want to have to pay for that sort of work if nothing can be found.
Dan
atc98092 is online now
post #43 of 60 (permalink) Old 02-10-2019, 11:17 AM
Car: 2016 Outback 2.5
I had the exact same thing happen the day before the OP incident.
Driving at 70 MPH when suddenly loss of power. No codes or anything else of note. Typical reaction to running out of gas. I had just under a quarter of a tank.
Flat bedded to dealership but they won't be able to look at it until tomorrow. I'm guessing fuel pump went out or something related.
I was within twenty miles of home when this occurred after making a 600 mile trip so lucky in that regard.
Mike Bennett is offline
post #44 of 60 (permalink) Old 02-10-2019, 11:21 AM
Jdog81's Avatar
Car: 2011 outback 2.5i limited cvt
so you mentioned it had a full tank of gas. did you happen to "top off" the fuel when filling. if you continue to top off when filling ,raw fuel enters the evap system. when the purge valve opens to vent fuel vapors from the charcoal canister, it instead gets raw fuel which becomes an unmetered rich condition. engine stall will result. this can also happen if the charcoal canister gets overwhelmed per say with raw fuel and you can get a vapor lock condition.
ammcinnis, AvidHiker and DugsSin like this.
Jdog81 is offline
post #45 of 60 (permalink) Old 02-10-2019, 06:48 PM
Car: 2015 Outback Limited 2.5
WOW. Not a CVT problem!!!
2015 Outback Limited 2.5 - 20MM rear Swaybar, Yokohama YK740 GTX 235/60-R18, Perrin Steering Lockdown
Biebs is offline
post #46 of 60 (permalink) Old 02-11-2019, 07:48 AM Thread Starter
Car: 2017 3.6R Limited with EyeSight
The primary issue is that the dealer tends to shrug their shoulders and say there is nothing they can do. No matter the cause, the car lost power at highway speeds. Thank God I wasn't on the beltway, or it could have been a serious accident.
Keep in mind that I've got a 3.6R, so I'm not sure if we're all seeing that same issues.
I've got fuel issue and I've got ignition system in mind, if it's not the transmission as the service manager suggested. (The trans should pop all sorts of codes, or at least you'd think.)
Car's got 40k on it, but is under 2 years old. I'm pretty sure lemon law is not in play. However, I can trade it in and walk away... given what we went trough with the wife's 2.5FB and the oil burning... I may do that if they claim not way to figure it out.
GBMaryland is offline
post #47 of 60 (permalink) Old 02-11-2019, 08:42 AM
Car: 2014 3.6R Limited
You guys ain't seen nothin unless you have seen the driving in Moscow! I saw cars 7 abreast on 4 lane roads. I asked a taxi driver how the H there aren't more wrecks. I loved his reply: "Make way for the fool!".
Biebs likes this.
Red Suburu is offline
post #48 of 60 (permalink) Old 02-14-2019, 07:38 PM
I'm a Marylander too and today, on the Virginia side of the Potomac Ocean, I went through a toll gate on the Dulles Toll Road and I and everyone else in the left hand lane was back up to 70mph as quickly as possible.
Folks in Metro areas, at least in the East, just drive faster. In Boston, it's insane.
viaggiatore is offline
post #49 of 60 (permalink) Old 02-15-2019, 08:44 AM
cardoc's Avatar
The dealerships are supposed to have updated information and diagnostic strategies in place and train the technicians to use them. The problem is lazy thinking and trying to make $$$$, both for the tech and service manager. The techs don't want to spend a couple or more hours on diagnostic testing when they only get paid an hour to do it, so they guess or assume and often change out complete systems in the hope that the problem will be rectified.
We've got a Nissan Murano AWD at the shop now. No codes on any system and bucking while driving like it's misfiring. Two people spent a lot of time going over this car to narrow down the issue. Both believed it was the transmission, a CVT, but couldn't say for sure. They've been doing diagnostic and repairs for a while and went through the module test, wiring, grounds, battery, engine management, transmission controls, etc.. The car would not act up on the lift and data logging didn't make anything apparent and certain. So, after I got a moment between cars I drove it. Acting like torque binding. In turns it was worse. Bucking in straight line with torque, cruising, and rolling in Neutral. Transfer differential is shot and needs a rebuild. The owner doesn't believe that it's the transmission because it acts like a misfire.
If this car was at the dealership, they would have charged the owner for unnecessary engine work because of the way it acts without looking for the real cause which would remain after all the work and cost to the owner. If the car was under warranty, that just means the owner doesn't foot the bill, but the techs still get paid, even when they misdiagnosed, or guessed wrong. And this is a problem because it leads to continued practice of guesswork instead of finding the real issue the first time. You wonder why your car is at the dealer so long, well, it's because they have your car in the bay and their first attempt at rectification failed so they've moved on to trying something else. "We're working on it" really means they can't find the issue and what they've tried thus far didn't work.
I'll give you another: A Jeep with a Hemi has codes for MDS solenoids and cam actuator. The dealer said it needed an engine. The engine NEEDED a pigtail harness that runs the MDS and cam solenoid because the one on the engine was frayed and shorting out at the connector behind the cylinder head. A $70 part and an hour to fix. That's not much compared to the cost of an engine and the labor to change it.
Lazy man works the hardest. And there's a lot of lazy men, and women, at the dealerships that try to take an easy way out and are more concerned with their paycheck than their work. Sometimes diagnostics is easy, sometimes not. It all depends on the person doing it and what their true aim is. For me, I love the puzzles. Give me a car without codes and I go old school and find the problem. But there's not a lot of people like me out there. So you take your chances.
On the OPs issue @GBMaryland
It seems to me that there is an unclear explanation as to how things transpired. I understand that in times of stress things seem to be in fast forward with a lot of things happening at once. So I want to ask, did the engine stall or did you shut it off and restart it? Was the engine running as you tried to get forward motion? If so, was the rpms going up without applying torque to the wheels to move it, or was it getting partial torque like it was slipping gear application? This erratic shifting you talk about, can you expand on it?
If the engine continued to run, that eliminates engine issues, but not communication.
If the engine sped up without transfer of torqued, that is either a communication issue between the ECM and TCM or a mechanical issue within the transmission. There are several things that can go on mechanically without setting a code. Torque converter failure doesn't always set a code. How many owners had a CVT or otherwise that had the shuddering torque converters and never had codes? Then there's slipping pulleys that if the pressure value reported to the TCM is within specs will not set codes. You also have broken parts where everything in the CVT is good but the outputs aren't able to function, such as broken CV shafts, broken gear teeth on the diffs, etc. Not everything has a monitor connected to it. If your dealer cannot find the problem, it's not the car's fault. It's the technician in which case you need another set of eyes on it. Contact SOA and get someone else to look at it or find the right independent tech that knows how to track these things down.
And I'll give you a bit of advice: All manufacturers are going to CVT because they help reduce emissions by keeping the engine running at a smooth torque transition instead of the constant shift in engine performance with a conventional automatic or manual transmission. They are constantly trying to update the operation of the CVTs through mechanical engineering and the software that runs it. So just like the times when autos first appeared, there will be issues after production that don't come up in R&D; just like any software, in any system whether car, office, home or your phone, glitches show up. Shite happens with cars and you have to roll with it. Is it frustrating, yes. It disrupts your commute, your schedule, your weekend sometimes. This can occur with any manufacturer's vehicle. It's not a problem just with Subaru. Trust me, I've seen a lot across the board in American, Japanese and European cars. It's all of them.
ammcinnis likes this.
cardoc is online now
post #50 of 60 (permalink) Old 02-15-2019, 09:19 AM
Pilot1226's Avatar
Car: 2019 Subaru Forester Premium, Crystal Black Silica, Pkg 15
+1. When the Torque Converter was starting to fail on my 2011 Outback, I never saw a code, but the car did stall at a stop sign on several occasions. They were able to diagnose the issue with a test that checked the pressure of the CVT.
As more and more cars get even more and more computerized, this problem will just continue on. But, all things said and done, I still think the cars today - despite their technological glitches - are much more safer than the stick shifts from 30 years ago without ABS, VDC, or any type of FCW/Prevention.
Pilot, Subaru Ambassador, Northern NJ Area
2019 Forester Premium, Crystal Black Silica & Black Cloth, Package 15
Former 2011 Outback 2.5i Limited & 2009 Legacy 2.5i Limited
Pilot1226 is offline
Oil change killed transmission (CVT)? S_T_473298562 Oil and Fuel Discussion 42 01-09-2019 07:57 PM
School me on CVT fluid levels and CVT failure Raych Gen 4: 2010-2014 39 01-27-2018 03:24 PM
CVT, CVT Version 2, HCVT, and 6MT questions Pilot1226 General Discussions 11 07-01-2017 01:37 AM
Drove the 2.0 DIT Forester Today: Engine and CVT Observations fun2drive Gen 4: 2010-2014 24 10-11-2013 01:37 PM
2013 Outback and Legacy Announced iainb General Discussions 8 03-29-2012 06:13 PM
