AWD problems...? - Page 3 - Subaru Outback - Subaru Outback Forums
 5Likes
post #21 of 46 (permalink) Old 03-21-2019, 04:42 PM
Car: 2016 OB LImited with 2.5, Lapis Blue Pearl, option package 23, body side molding, door edge guard
Originally Posted by Bluestar2 View Post
I can relate to Subaru quality problems. My 2015 2.5 Outback has had following warranty work: I am on my third dashboard and third driver panel due to quality issues, rear hatch failed to open, blown fuse, left front axle replaced, drive shaft replaced, high speed vibration that canít be resolved even with new tires and wheels. Interesting though, my wifeís 2016 Forester has not had one problem. Is it the difference that Outbacks are built in US and the previygeneration Foresters were built in Japan?
You cannot draw any conclusion on two data points (one Outback and one Forester). One would need data from many of these vehicles
bluie is offline
post #22 of 46 (permalink) Old 03-21-2019, 04:43 PM
Skidad's Avatar
Car: 2006 Mazda MPV ES, 3.0 liter V6
YIKES
Thatís really disheartening!!
Skidad is offline
post #23 of 46 (permalink) Old 03-21-2019, 04:54 PM
That's what I find so entertaining about forums and how infantile many adults are. Look at recall guy- he's a hoot.
"I had two brand X cars that never gave me a problem and now this brand Y car had a problem- they're junk last one I buy."
Find these on every forum of ever manufacturer.
originaltwotone is online now
post #24 of 46 (permalink) Old 03-21-2019, 04:59 PM
Originally Posted by Lowell_Greenberg View Post
Yes-but it IS an indication of quality control. The valve spring recall disaster is another indication. And there is a relationship between quality and reliability. I think Subaru reliability across most models is good- but not great, and QA issues are a key factor.
Sent from my SM-G975U using Tapatalk
Originally Posted by Skidad View Post
We have one guy only so far working on the valve spring issue. Heís young and a real good tech but on one he had to drop the motor a second time due a noise that would only happen after the motor had run for like 45 minutes or more. He wasnít the only one experiencing this problem.
I doubt Subaru makes their own valve springs. Unfortunate and expensive supplier blunder.
I'd love to hear LG's expert opinion on how to check for things like material impurities in manufacturing without considerable added expense.
I was an A&P a long time ago. I still remember small aircraft starters that were basically the same as automotive but cost many times as much. I was told the additional cost- added inspections and QC during the manufacturing.
post #25 of 46 (permalink) Old 03-21-2019, 05:39 PM
ammcinnis's Avatar
A couple of decades two ago I had the OE starter off a Lycoming O320 that needed overhaul, so with my A&P's blessing I took it to the owner of a long-established rebuilder of automotive starters, generators, and alternators. He immediately identified it as a Model B Ford starter, right down to the same Bendix drive. Of course, the cast aluminum mount was different to fit the Lyc, but the rest of the starter was pure 1930s technology.
ammcinnis is offline
post #26 of 46 (permalink) Old 03-21-2019, 06:36 PM
Danver's Avatar
Originally Posted by ammcinnis View Post
A couple of decades two ago I had the OE starter off a Lycoming O320 that needed overhaul, so I took it to the owner of a long-established rebuilder of automotive starters, generators, and alternators. He immediately identified it as a Model B Ford starter, right down to the same Bendix drive. Of course, the cast aluminum mount was different to fit the Lyc, but the rest of the starter was pure 1930s technology.
Solid choice. After all back in the day you never heard of many Model Bs falling from the sky.
Danver is online now
post #27 of 46 (permalink) Old 03-21-2019, 07:00 PM
Lycoming is now being dragged into modern engine technology today. Its sad to see small shops building far more advanced engines and redundant technology while Lycoming hangs onto 1930ís engine designs.
On the flip side it was cool filling 5gal gas cans at the Chevron station on the way out to the hangar.
subiesailor is offline
post #28 of 46 (permalink) Old 03-21-2019, 07:02 PM
majpooper's Avatar
Car: 2018 Outback Limited 3.6R 2" ADF lift kit 17X8 (45mm off-set) Advanti DST Storm wheels 245/65R17 BFG KO2 AT tires 20mm RSB Strut Tower Brace steering Dampener Lockdown
Sometimes I think it is just the particular vehicle although brands do get reputations like Toyota for reliability or the old Plymouth slant six engine etc.
2018 OB 8k miles no issues 2017 Crosstrek 20k miles no issues 2013 Honda CR-V 100K miles still no issues - my wife won't let me get rid of it. Had a 2002 MB Kompressor was always in the shop, once it went out of warranty I dumped it - both times I took it in after warranty the bill was in the $300 range - great customer lounge though and even offered to take me to breakfast. The worst car I ever had was a Mercury Linx (a re-badged Ford Escort) my brother and a friend had Escorts I said they were great "no problems" I had a timing belt go and the transmission lock up both cost an arm and a leg plus the car had a weak engine and was ugly - I hated that car.
2018 Outback Lmited 3.6R
majpooper is offline
post #29 of 46 (permalink) Old 03-21-2019, 10:41 PM
Well, I'm not an expert. Though I have designed and developed software applications, and tracked quality issues on heavy machinery. And I feel there are no simple answers. Quality is a combination and outgrowth of many factors. Design, materials, tolerances, testing, testing, testing, manufacturing process, environmental factors, people, etc. Whatever it is, it is no accident.
And while there is always a cost vs benefit consideration, smart, ethical manufacturers place a premium on safety, reliability and durability. There will always be companies that sacrifice quality for cost to drive sales volume. They calculate safety as a cost of doing business and even weigh lives versus dollars.
I think Subaru is a good company that knows it needs to improve its overall brand quality. It"s past history of engine issues is hopefully behind it. I also hope their CVT transmissions continue to improve in durability.
Lowell_Greenberg is offline
post #30 of 46 (permalink) Old 03-21-2019, 11:41 PM
You brought up the valve spring issue as one of the reasons Subaru needs to improve quality.
It was a materials impurity issue from a supplier, so again, I'd like real answers to how a company prevents those types issue without driving costs up exponentially?
It's always so easy to come on a forum ans say brand X needs to do this, but noone ever seems to have actual answer on how.
AWD vs Front Wheel Drive. The debate rages on scoobydoo2 News & Media 19 03-02-2018 11:23 PM
Flat Tires, Disabling the AWD & 5th Gen Outbacks jimh009 Gen 5: 2015-2019 11 11-01-2016 08:33 PM
2003 forester manual awd to auto awd ? commodore1600 Gen 2: 2000-2004 7 08-30-2016 08:58 AM
00 OBW awd problems. low power to rear jrouse5 Problems & Maintenance 13 02-14-2011 02:49 AM
Are all AWD systems created equal? johnsora General Discussions 14 11-16-2005 04:00 PM
