Emergency brake in mountains - Page 2 - Subaru Outback - Subaru Outback Forums
 16Likes
post #11 of 52 (permalink) Old 04-08-2019, 01:15 AM
If your moving and hold the electric parking brake button it engages at a lower tension than it does when stopped. Its a industry standard thing all electric parking brake cars have this reduced tension step to avoid causing total loss of control. And yeah it chirps and barks at you a bunch.
mdywv likes this.
subiesailor is offline
post #12 of 52 (permalink) Old 04-08-2019, 09:41 AM Thread Starter
Car: 2001 Subaru Outback LL Bean, 3.0 H6
I have lost brakes on a 2001 subaru completely. This was in 2005 with 50k miles on it. So don't try to say it will never happen. If it does and I lose control of the car and I'm still alive afterwards I will sue the crap out of Subaru. I don't see how this is safer. How did I lose the brakes? Well... a previous owner did not route the caliper hose thru the shock. The hose rubbed on the tire and cut the line. Luckily it happened in a residential area. What till it happens to you bud.
tsloyan is offline
post #13 of 52 (permalink) Old 04-08-2019, 09:51 AM
AvidHiker's Avatar
Car: 2015 3.6R Limited
Uhh, but it seems we've already established that it will also function as an e-brake, and I've yet to see any evidence that's it's any less safe or reliable than past designs. Nobody said brakes can't fail, simply that it's extremely rare, particularly when the system has been competently maintained. If you have such a grave concern about travelling in the mountains, I'd suggest having the brake system inspected by a trusted mechanic before your trip.
AvidHiker is offline
post #14 of 52 (permalink) Old 04-08-2019, 10:01 AM Thread Starter
Does ABS function? I'm moving to summit county. I will always be in the mountains. What is the inspection going to do? You could have a seal blow on a caliper due to defect. There are a ton of ways to lose your brake. I'll find out from the dealer later.
tsloyan is offline
post #15 of 52 (permalink) Old 04-08-2019, 10:21 AM
Location: Sometimes in Colorado - Sometimes in Pennsylvania - Snowbird with bad sense of direction & humor
Car: 2017 Outback Limited -2.5 CVT ---- 'Gone' 2014 Outback Limited - 2.5 CVT ---- 'Rehomed' 2012 Outback Limited - 2.5 CVT - Deep Indigo Pearl ---- "RIP" 2010 Outback - 2.5 CVT - Silver - So's my hair - what's left.
This wasn't a brake failure... Owner/Maintenance failure maybe.
There are all kinds of 'brake failure is imminent' warnings built into modern vehicles. Brakes rarely fail without some noise or other warning.
Why would the ABS system still work in a brake failure? It's part of the system.
"I'm moving to summit county".... I'd be more worried about some stoner not using/having brakes.
Ali Pine is offline
post #16 of 52 (permalink) Old 04-08-2019, 10:30 AM
Car: 2019 Blue Outback in Premium trim
Originally Posted by johnre View Post
Losing he conventional braking system is so rare a thing that it's not worth worrying about. You probably have a better chance of being struck by lightning. Just maintain it well and be done with it.
Now, what you can worry about with these newfangled parking brakes: How do you ever pull manage to off this maneuver any more?
https://www.youtube.com/watch?v=NlaQGCr0dfI
I know! This has really adversely affected my moonshine distribution business.
W8MJE is offline
post #17 of 52 (permalink) Old 04-08-2019, 11:18 AM Thread Starter
Lol. I talked to the dealership. ABS does kick in. Shouldn't be an issue. I still don't like it for fun reason but at least it is safe. So losing brakes are not a brake issue? Ok.
tsloyan is offline
post #18 of 52 (permalink) Old 04-08-2019, 11:24 AM
are there still 2 circuits from the master cylinder? That is, if you lose a seal at a caliper, don't you still have (temporarily I guess) 1/2 braking ability from the other front and its diagonal rear pair?
1 Lucky Texan is offline
post #19 of 52 (permalink) Old 04-08-2019, 11:24 AM
In Vermont, total brake loss on a 10+ year old car is pretty common. The flexible lines in the front rot and the metal brake lines eventually corrode and fail. Vermont vehicle inspection is pretty picky about making sure emergency brakes work since people actually have to use them.
I assume EyeSight is using the electronic rear brakes on hill descents and anti-collision braking? I never use the e-brake and I'd think it sees enough use from EyeSight that it will be there if I need it.
GeoffD is offline
post #20 of 52 (permalink) Old 04-08-2019, 11:32 AM Thread Starter
Lucky texan,
I didn't know that. I think what upsets me most with the new tech is that I lose control over things. I've never been a big fan of ABS, I'm still not but I've learned to live with it. I didn't have ABS in any car I drove until 2010. I can turn off all the other annoying features but ESC and the emergency brake. Although now that I know ABS will kick in and I can pull it off/on I would not hesitate to take the car down the mountain. I feel pretty safe now. Neither the release and go procedure nor the ABS feature are explained in the manual well. I'm glad I opened this thread. I def learned a lot. Thank you all again.
tsloyan is offline
2018 Cold Side Brake Pedal Wire TacoTuesday Electrical & Electronics 4 04-09-2019 04:03 PM
Brake Bleeding 00 Subaru Outback Base with ABS SATEXASSUBARU Gen 2: 2000-2004 3 01-27-2018 07:35 PM
06 outback parking brake slip itzz Problems & Maintenance 16 05-20-2012 07:44 PM
Need advice / spec on Emergency brake adjustment TourNut Problems & Maintenance 2 08-09-2011 06:37 PM
lack of emergency brake on 2010 model DavidZ Gen 4: 2010-2014 53 07-19-2010 07:33 PM
