Cruise control settings - Page 3 - Subaru Outback - Subaru Outback Forums
 24Likes
post #21 of 32 (permalink) Old 04-18-2019, 10:59 PM
RoadTripBoy's Avatar
Car: 2019 Outback 3.6R Limited with Nav/Moonroof/RAB-Rear CrossTraffic Alert
Originally Posted by jthomas View Post
Thanks. Actually it's on p. 48 in the 2019 Eyesight manual.
That just seems backwards to me. If I'm cruising at the speed limit of 70 on the interstate and find I'm passing a car in the right lane very slowly I want to speed up by one or two mph to get around him, not 5mph. A couple of clicks does it on my Tahoe, but not on the Subaru.
Agreed! Every cruise control I've ever had has increased by 1 mph for each "tap" of the button. But this isn't your father's cruise control! :-) Seriously I'm awestruck (and a little disconcerted) by how the car can slow itself to a stop if necessary with the adaptive cruise control on.
RoadTripBoy is offline
post #22 of 32 (permalink) Old 04-19-2019, 09:47 AM
ELCID86's Avatar
Car: 2018 OB Limited 2.5
This did seem counterintuitive but Iím getting used to it (not my DD). I do love the ACC. (I too learned about it hereóthanks.)
Shawn in VA (USA)
ELCID86 is offline
post #23 of 32 (permalink) Old 04-19-2019, 11:02 AM
Ron T's Avatar
Car: 2019 Outback premium, 2.5
Originally Posted by Zedhead View Post
It's a 2 stage switch. A large press nets 5 mph increase. A light press nets 1 mph increase
Wrong. Short press or "bump" results in a 5 mph change. Long press or "hold" will result in a 1 mph change if you release in time.
Ron T is offline
post #24 of 32 (permalink) Old 04-19-2019, 11:23 AM
atc98092's Avatar
As others here have noted, it's model year dependent. Older Outbacks, I believe 2017 and older, it is the way Zed described. For MY2018, they reversed it for some unknown reason.
ammcinnis likes this.
Dan
atc98092 is offline
post #25 of 32 (permalink) Old 04-19-2019, 11:28 AM
Danver's Avatar
Yes, my '17 works the way Zed described. I'm sure either way is easy enough to get used to but it must suck if you regularly switch back and forth between different model years.
Danver is offline
post #26 of 32 (permalink) Old 04-19-2019, 11:34 AM
Ron T's Avatar
A service rep at our dealership was surprised to learn of this glaringly stupid programming change. He suggested contacting customer service to lodge a complaint. I will do so, and implore all of you to do so as well! The increment of change is controlled by software and a quick update will correct this shortcoming in the cruise control that is otherwise a fantastic bit of tech. So PLEASE contact customer service and request this change! I know, your're used to it and it may not be a big deal to you, but it's WTF the first time you experience it! plus it's counter to the overall safety focus of the brand, fine tuning the setting by paying extra attention the instrument panel instead of the road.
Ron T is offline
post #27 of 32 (permalink) Old 04-19-2019, 11:56 AM
Danver's Avatar
Sometimes I wonder how people manage to make it through a day, let alone an entire life.
Danver is offline
post #28 of 32 (permalink) Old 04-19-2019, 12:10 PM
Ron T's Avatar
Ron T is offline
post #29 of 32 (permalink) Old 04-19-2019, 12:25 PM
Car: 2015 Outback Limited w/ES, Wilderness Green
I suspect Danver was commenting about our modern tendency to get all worked up over very small issues. Yes, it is curious that they changed the switch progamming, but to start a complaint campaign? Really?
jdupton and ammcinnis like this.
mlsstl is offline
post #30 of 32 (permalink) Old 04-19-2019, 01:06 PM
ammcinnis's Avatar
... this glaringly stupid programming change ... PLEASE contact customer service and request this change!
It's not at all clear which implementation you consider "stupid." Regardless, at this point you have the usual three options:
  • You can continue whining about the issue, which will accomplish exactly nothing.
  • You can adapt to the way your Outback actually works, and get on with your life.
  • You can buy a different vehicle.
It's your choice.
ammcinnis is online now
Cruise Control Issues BISCUT Gen 5: 2015-2019 7 05-24-2017 11:18 AM
Cruise Control Problems Flyboy_2404 Problems & Maintenance 24 02-06-2017 01:01 AM
2000 Outback Wagon - Cruise Control not working Kitesurf Problems & Maintenance 17 08-01-2014 05:54 PM
Intermittent Cruise Control after code 420 repair imaric Gen 3: 2005-2009 3 04-11-2012 09:17 PM
Engine light on + Cruise control flashing after service / cam belt change swedenuk Problems & Maintenance 9 02-19-2012 10:23 PM
