Car sometimes fails to start on first try. - Page 2 - Subaru Outback - Subaru Outback Forums
 3Likes
post #11 of 16 (permalink) Old 04-15-2019, 09:30 PM
Tishers's Avatar
Car: 2007 2.5 L Obsidian Black Outback XTL
Originally Posted by JoeH View Post
Car has always started on the second try. When this usually happens, motor is warm (driven a half-hour prior). Never had this happen in 50+ years of driving.
Really?? Admittedly I do not have your extensive driving experience; as I only having had a license for the last 40 years, but I remember until the late 1980's that if often took 3-4 cranks to start a car. Sometimes you even had to do things with a choke lever and on some mornings I even had to ride the throttle to keep the car from stalling out until it warmed up.
But 50 years, I didn't know that those 1968 models always were so reliable that they always started on the first turn of the key.
ammcinnis and Biebs like this.
Greetings from the leading factory authorized interocitor service center of the Milky Way galaxy for the last three millennia. If you are in the Orion arm stop by to see the latest models. Now with interdimensional mutate capabilities!
Sol system, third primary planet. (Excuse our mess! Just ignore the bipedal life forms, their extinction is under way).
Tishers is offline
post #12 of 16 (permalink) Old 04-15-2019, 09:51 PM
Car: 2015 Outback Limited 2.5
Sounds like a fuel pressure problem
Or bad gas
2015 Outback Limited 2.5 - 20MM rear Swaybar, Yokohama YK740 GTX 235/60-R18, Perrin Steering Lockdown
Biebs is offline
post #13 of 16 (permalink) Old 04-16-2019, 12:14 AM
Car: 2017 3.6R Limited with Eye Sight
The only time my car had trouble starting was the day after I washed it.
Moisture got somewhere it shouldn't have.
John Doe is offline
post #14 of 16 (permalink) Old 04-16-2019, 07:59 AM Thread Starter
Car: 2019 Outback premium. Tungsten metallic.
Notice I pointed out "when the motor was warm". You said "until it warmed up". Think before you type.
JoeH is online now
post #15 of 16 (permalink) Old 04-16-2019, 09:27 PM
Car: 2017, Premium/ES, 2.5L, Auto Trans
Originally Posted by bartold73 View Post
That is not true. The dials all do a swing during startup.
Sorry I was not more explicit. The dials swing to full scale and back to zero when the ignition is turned on. But if you pause till after the dials are done with their turnon dance, then crank the engine, the tach will show the cranking speed until the engine catches and runs. In most cars these days, the tach barely has time to register before the engine fires and runs up to idle. So it's easy to miss. But if the car isn't starting, you will have more time to see if the tach shows cranking speed. If not, the ignition is not firing. If the tach shows the ignition working, start troubleshooting with the fuel system.
Since OP notices his starting problems after a short shut down, something is heat soaking. That can affect electronic ignition components or fuel. I just tossed up an old school way to make that first cut. Yes, I have seen exactly that symptom before as an ignition component gets weak.
skipw likes this.
KSKarl is offline
post #16 of 16 (permalink) Old 04-16-2019, 10:04 PM
Car: '15 Outback 2.5i Premium
Thanks for posting that, Karl. Saved me the trouble of checking to see if the tach moved a noticeable amount when cranking, especially since mine usually fires right up (knock wood!)
OP may have a problem with the immobilizer. "Always starts on the second try" makes that seem less likely, but it's still a possibility.
skipw is online now
Subaru Tuning that affects 5EAT Operations & Performance by Xtreme Racing Tuning west_minist Parts, Accessories, & Performance 46 07-25-2018 03:00 PM
Idiot 5eat and 3.0 questions Riom4 Gen 3: 2005-2009 23 04-23-2014 06:12 AM
Car randomly isn't able to start smartzk24 Gen 2: 2000-2004 21 12-18-2013 08:02 PM
Selling or Trading In Your Old Car Hammonddave Gen 4: 2010-2014 19 11-08-2011 02:16 PM
