Adaptive Cruise Control - brakes or throttle? - Page 2 - Subaru Outback - Subaru Outback Forums
 7Likes
post #11 of 20 (permalink) Unread 04-15-2019, 03:08 PM
Car: 19 Outback 3.6r Touring, 12 Forester X, 09 G8 GXP, 08 BMW 535xi
Originally Posted by IcePick View Post
I find it annoying, you speed up to pass someone on a 2 lane and in all previous vehicles I have owned you let off the pedal and let the car coast back to the cruise set speed.
Not the outback, it will apply the brakes to get you back to set speed quicker - making you look like a tool for passing someone and then hitting the brakes.
I turn off the cruise before passing now.
That’s because you speed to pass them and then go back to your speed...
Illegal to exceed the speed limit, even to pass.... (yes annoying, still illegal and yes we all do it)
SmokeyBear is offline
post #12 of 20 (permalink) Unread 04-15-2019, 03:30 PM
I'm not sure what illegal has to do with it, the ACC is just slowing down to the speed selected. Are you saying it knows the speed limit and only uses brakes if you are above it?
I have not noticed that it's using braking to get back to the selected speed. I will check that out going home tonight.
Beary
Beary is offline
post #13 of 20 (permalink) Unread 04-15-2019, 03:34 PM
Beary
It knows the speed you have it set at... so when you go above that to pass, depending what you got up to it will brake to get back to what you set it at. If you just come up on someone say going 40 in a 60... You signal, go around, and go back, the brakes will not be applied.
post #14 of 20 (permalink) Unread 04-15-2019, 03:35 PM
Car: 2018 Outback 2.5i Limited Eyesight - Remote Start - Auto Dimming In/Outside Mirrors
It depends how fast you go above the cruise setting if brakes are applied I have noticed.
rockyp and ammcinnis like this.
- Eyesight - Remote Start - Auto Dimming In/Outside Mirrors
- Ivory Leather - 8" Navigation
theoak is offline
post #15 of 20 (permalink) Unread 04-15-2019, 03:57 PM
ammcinnis's Avatar
... it will apply the brakes to get you back to set speed quicker - making you look like a tool for passing someone and then hitting the brakes.
Don't blame the vehicle for trying to do do exactly what you tell it. If you want to avoid CC braking in such a situation, just feather the throttle to decelerate, rather than lifting your foot completely, until your speed is within about 5-8 mph of the set point.
That's another good solution.
SmokeyBear and atc98092 like this.
"If you don't know where you're going, any road will take you there." ~ Lewis Carroll (Alice in Wonderland)
ammcinnis is offline
post #16 of 20 (permalink) Unread 04-15-2019, 04:52 PM Thread Starter
Car: 2019 2.5i Premium
I haven't had this car long enough to discover that. Glad I learned about it before experiencing it.
jthomas is offline
post #17 of 20 (permalink) Unread 04-15-2019, 11:47 PM
Originally Posted by atc98092 View Post
It can also "downshift" the CVT to apply some engine braking. Generally does this for holding speed going downhill.
Also, if it applies the brakes at a "moderate" or greater level, the brake lights come on. So it provides warning to someone following.
I actually noticed this today. I was going down a hill on the freeway and while other cars had their brakes on the whole way down, my car was maintaining speed without using the brakes. I couldn't feel the downshift either since it's CVT. It was kind of cool, but at the same time I felt it might be a little dangerous for the car behind me as the driver wouldn't really have an indication that I was slowing down.
djxpress is offline
post #18 of 20 (permalink) Unread 04-16-2019, 08:15 AM
atc98092's Avatar
If it slows quickly enough to be an issue for someone behind you (assuming they aren't tailgating) the brake lights come on. The dash display shows when the lights come on, even when you press the brake pedal yourself.
Dan
atc98092 is online now
post #19 of 20 (permalink) Unread 04-16-2019, 09:57 AM
Fingers crossed they are driving with their eyes open
theoak is offline
post #20 of 20 (permalink) Unread 04-16-2019, 11:26 AM
The car shouldn't be driving up on you because the engine braking isn't slowing you down, it's maintaining the same speed.
Where I get a little nervous is when the ACC reacts a little slower than I would in traffic requiring it use the brakes pretty hard. I can see the traffic slowing down several cars ahead while the ACC is reacting to the one car in front. I tend to turn off the cruise in this situation even though I have full confidence the system will function correctly. I'm just less jerky about it.
Beary
KSKarl likes this.
Beary is offline
Braking with Cruise Control. Pros and Cons ? scalman Gen 2: 2000-2004 10 03-16-2018 05:02 AM
2006 Outback Cruise Control problems jptra Problems & Maintenance 23 06-12-2016 02:47 PM
Do any of you also have those "DOH" moments using Adaptive Cruise Control? TimmyB Gen 5: 2015-2019 12 10-05-2015 06:32 PM
P0420 and Cruise Control Hesitation wildcatsubaru Problems & Maintenance 8 07-13-2014 07:26 PM
"Check Engine" ODB-II / ODB2 Code Reference JazzyMT Problems & Maintenance 1 05-10-2006 04:22 PM
