Adaptive Cruise Control - brakes or throttle? - Subaru Outback - Subaru Outback Forums
 7Likes
post #1 of 20 (permalink) Unread 04-14-2019, 09:00 PM Thread Starter
Car: 2019 2.5i Premium
An acquaintance on another forum drives a '16 Outback in England. He says the adaptive Cruise Control always uses braking to slow the vehicle when there is a slower vehicle in front. I have minimal experience with this so far, but I assumed it just reduced the throttle setting.
Which is correct - brakes or throttle? Or both?
jthomas is offline
post #2 of 20 (permalink) Unread 04-14-2019, 09:15 PM
Car: 16 Outback 3.6R
Both. It'll come to a complete stop if necessary.
Sent from my OnePlus 5 using Tapatalk
Darter is offline
post #3 of 20 (permalink) Unread 04-14-2019, 09:44 PM
ammcinnis's Avatar
Both. Throttle reduction first, followed by service brakes as needed. You can observe brake application on the car symbol in the Multi-Function Display.
OBnube likes this.
"If you don't know where you're going, any road will take you there." ~ Lewis Carroll (Alice in Wonderland)
ammcinnis is offline
post #4 of 20 (permalink) Unread 04-14-2019, 10:14 PM Thread Starter
Thanks. I'll try to remember to look for the indicators next time.
My friend in England seems to think that it uses only brakes, but apparently he has quite a lot of traffic to contend with, with other drivers cutting in. That would require brakes.
jthomas is offline
post #5 of 20 (permalink) Unread 04-15-2019, 08:41 AM
atc98092's Avatar
It can also "downshift" the CVT to apply some engine braking. Generally does this for holding speed going downhill.
Also, if it applies the brakes at a "moderate" or greater level, the brake lights come on. So it provides warning to someone following.
Dan
atc98092 is online now
post #6 of 20 (permalink) Unread 04-15-2019, 09:17 AM Thread Starter
I noticed that. First car I've ever had on which the CC will hold speed going downhill.
theoak likes this.
jthomas is offline
post #7 of 20 (permalink) Unread 04-15-2019, 10:13 AM
Mine doesn't do much in the way of engine braking when I'm mountain driving. I have to use the faux gear select on the CVT with EyeSight disabled to engine brake. My Vermont place is in the land of revenue-generating speed traps. It would be very nice if I could use EyeSight to hold speed but it would chew through my brakes quickly.
GeoffD is online now
post #8 of 20 (permalink) Unread 04-15-2019, 12:14 PM
ammcinnis's Avatar
I think you mean "ACC" rather than "EyeSight." ACC is just one function provided by the EyeSight system.
post #9 of 20 (permalink) Unread 04-15-2019, 01:04 PM
atc98092's Avatar
True, gas powered engines don't offer as much engine braking as a diesel with an exhaust brake. But every little bit helps. I'm sure they don't let the RPM climb too high. Mine seems to settle about 2500 max.
Dan
post #10 of 20 (permalink) Unread 04-15-2019, 03:01 PM
Car: 2017 2.5i Outback Limited w/ES
I find it annoying, you speed up to pass someone on a 2 lane and in all previous vehicles I have owned you let off the pedal and let the car coast back to the cruise set speed.
Not the outback, it will apply the brakes to get you back to set speed quicker - making you look like a tool for passing someone and then hitting the brakes.
I turn off the cruise before passing now.
IcePick is online now
Braking with Cruise Control. Pros and Cons ? scalman Gen 2: 2000-2004 10 03-16-2018 05:02 AM
2006 Outback Cruise Control problems jptra Problems & Maintenance 23 06-12-2016 02:47 PM
Do any of you also have those "DOH" moments using Adaptive Cruise Control? TimmyB Gen 5: 2015-2019 12 10-05-2015 06:32 PM
P0420 and Cruise Control Hesitation wildcatsubaru Problems & Maintenance 8 07-13-2014 07:26 PM
"Check Engine" ODB-II / ODB2 Code Reference JazzyMT Problems & Maintenance 1 05-10-2006 04:22 PM
