CORRECT Battery Group for 2018 OB - Subaru Outback - Subaru Outback Forums
 5Likes
post #1 of 33 (permalink) Old 05-13-2019, 11:10 PM Thread Starter
Auto parts store couldn't tell me what battery I needed today, go figure.
I am reading on this forum that it is a 24 or a 34? Which is the OEM? Is it a 24F? Not sure what the F signifies?
kmc0929 is offline
post #2 of 33 (permalink) Old 05-13-2019, 11:26 PM
Car: '15 Outback 2.5i Premium
OE is Group 25. Group 34 is about 1" longer in length, about the same width, but 1" less height, so it has about the same internal volume. Group 24 is about the same length and width as group 34, but the same height as group 25, so it has the greatest volume of the three, so potentially can have the greatest capacity, all else equal.
Apparently all three will fit into the battery tray of a Gen5 Outback. You may need a spacer under a group 34 battery to make it a little taller so everything fits just right. If you have no unusual requirements, just get a good quality group 25 battery.
ammcinnis likes this.
skipw is online now
post #3 of 33 (permalink) Old 05-14-2019, 06:44 AM
Hogndogz's Avatar
Car: 2017 2.5 Outback Ltd
I recently replaced the oem group 25 in my '17 OB with a group 24 battery based upon the info in a previous post. Either a group 24 or 34 will be an upgrade from the weak oem battery. I chose the group 24 Walmart Maxx with 770 CCA & 130 reserve min. 3 year replacement & additional 2 year pro rated warranty for $120. It fit perfectly in the battery tray.
"Most of the things I worry about
never happen anyway"
Tom Petty
Hogndogz is offline
post #4 of 33 (permalink) Old 05-14-2019, 08:35 AM
freckles1219's Avatar
Car: 2019 Outback 2.5i Limited
That would cause me to quickly lose all confidence in that auto parts store. Car batteries are pretty basic. Hopefully, you have other auto parts stores in your area that are a little more knowledgeable.
Old car: 2005 Subaru Outback 2.5i
New car: 2019 Subaru Outback 2.5i Limited
freckles1219 is online now
post #5 of 33 (permalink) Old 05-14-2019, 10:06 AM
For whatever reason, the '18 and later OBs don't seem to be in the cross-reference lists. Up to '17 is there, but not later. There's probably a sticker on the OE battery that says what its group (or size) number is if you don't want to rely on something someone on the internet told you.
There are several vendors whose group 25 batteries are an upgrade from the stock battery. There's no need to change to a group 34 unless you want to for some reason; some vendors might offer the type of battery you want in 34 but not 25, so that's a good reason to go that route (Optima Yellow Top comes to mind). Group 24 is physically larger, so if you want the extra capacity, that is an option.
skipw is online now
post #6 of 33 (permalink) Old 05-14-2019, 11:38 AM
DAG
Car: 2018 Outback 2.5 Touring, 2005 WRX
Speaking of Optima, I've read and heard that they are now owned/manufactured? by another company and that quality is not what it has been. Some reviews are extremely critical. Anyone else have recent experience?
DAG is offline
post #7 of 33 (permalink) Old 05-14-2019, 11:45 AM
ammcinnis's Avatar
Optima was acquired by Johnson Controls (probably the largest automotive battery manufacturer in the U.S.) in 2000. More recently, I believe the manufacturing plant for Optima batteries has been moved from Colorado to Mexico, but that is unconfirmed. Concerning the product quality trend, all I have seen are scattered anecdotal reports ... both good and bad.
ammcinnis is online now
post #8 of 33 (permalink) Old 05-14-2019, 10:42 PM Thread Starter
So if I change it to a Group 24 battery, what do I do about the battery wrap / insulation part?
kmc0929 is offline
post #9 of 33 (permalink) Old 05-14-2019, 11:37 PM
Toss it. It's a piece of cardboard with a strip of foam around the top.
skipw is online now
post #10 of 33 (permalink) Old 05-15-2019, 01:13 PM
I did notice that searching online for a battery for my 2018 Outback came up blank at several sites. Just confirming that. I was looking because a friend has a 2019 Limited that is about six months old that has succumbed to the dead battery curse at least three times. One suggestion in one of the threads on that issue suggested a larger battery. I think that ignores the larger issue of why this is happening (let's not start that discussion again in this thread), but it did bring me to look at alternative batteries. Thanks for the info here on the groups that will fit my car. I've not had a problem, but I now live out west and hike / camp in some remote areas where a dead battery would be a major issue.
Tom
2018 Outback Premium
Tom03 is offline
Variable Voltage Alternator and Trailer Battery Charging clmbr256 Gen 5: 2015-2019 8 03-06-2018 11:20 PM
What group battery for 06 outback danlvan Gen 3: 2005-2009 9 11-20-2017 10:26 AM
Optima Red Top battery Group 35 (R) Peaty Electrical & Electronics 53 01-15-2016 11:34 PM
Correct location for battery cable negative grounds? puro Gen 1: 1995-1999 2 01-06-2016 04:50 PM
Please Help a Girl Out(back)! Battery Mysteriously Losing Charge NFSUBARU Problems & Maintenance 12 05-28-2010 01:22 PM
