You might have a DIY problem when... - Subaru Outback - Subaru Outback Forums
 3Likes
post #1 of 42 (permalink) Old 02-22-2012, 02:19 PM Thread Starter
Car: 2006 2.5i and 2002 3.0 wagons.
There is nothing outstanding on the "Things the car needs serviced and/or repaired" list.
I'm down to replacing the cabin air filter and refreshing the power steering fluid. Well, and the constant drill out and replace rusted off bolts...but that doesn't really count. One of them break pretty much every time I touch the car.
But my "To Do" list is almost empty and making me twitchy. Nothing to tinker on.
Have you considered the Google search bar at the top of the forum?
Ours:
2002 Outback wagon 3.0 L.L. Bean no more: "Mal" 135,000 and counting.
Cloth interior swap. HIR1 high beam upgrade. Yellow Lamin-X fog light film.
2006 Outback 2.5i wagon: "Professor Sprout" 97,000 and counting.
Family fleet:
2006 Outback XT Limited.
109,000 and bone stock.
Previous:
"Solstice" 1996 Outback wagon, totaled at 115K.
"Kaylee" 2003 Outback wagon, sold at 167K.
AWDFTW is online now
post #2 of 42 (permalink) Old 02-22-2012, 02:29 PM
Buy a wood sailboat and learn how to sail. Your car will soon rust away and you will not care because you will be 100% into the sailboat and tinkering with it. LOL
Full disclosure - I own two sailboats but they are fiberglass I have a job and family so no time for a wood one.h
subiesailor is offline
post #3 of 42 (permalink) Old 02-22-2012, 02:46 PM
How about adding 25 grounding wires, in bright colors, just for the heck of it?
xvimbi is offline
post #4 of 42 (permalink) Old 02-22-2012, 02:56 PM
Euchre's Avatar
Are all of the fasteners 'clocked'? If you didn't know, this is when you orient all of the fasteners in the vehicle to be basically the same. Philips head are all X or cross oriented, hex are all flat/points in the same direction, etc. That process could take you years.
jhodges likes this.
Come all without, come all within.
You'll not see nothing like
The Mighty Quinn!
Euchre is offline
post #5 of 42 (permalink) Old 02-22-2012, 03:36 PM Thread Starter
I have contemplated adding a grounding kit. Never gotten around to it though. Worth the time/funds?
*eye twitching* At this point, I avoid touching any metal fastener I do not have to. Too many have sheared off already (hate you so much rust!) during routine maintenance. That reminds me, I need to replace the bolts on my washer fluid reservoir before they snap, they had me worried at the last plug change. And drill out the bolt the snapped off on my intake. And...I hate rust.
Ours:
Family fleet:
Previous:
post #6 of 42 (permalink) Old 02-22-2012, 03:50 PM
I am not sure about this myself. I don't think it can hurt, provided it's done properly. And it might very well help if the car is oldish, in which case it is not unlikely that the grounding has suffered.
I think it's something one has to try to see if it has an impact; impossible to predict. One way to go about it, I guess, is to hold off on putting proper connectors on the wires, attach them and first see which connection has an impact, if any. Once you have determined that there is a benefit, then you can go ahead and make everything nice and shiny.
In the end, I don't think it's that expensive, even if you were to replace the battery terminal plugs ($10-30), went with 0/1 awg oxygen-free copper wire and nice terminals. Could probably replace the positive cables as well and have it all done for less than the OEM cable set.
xvimbi is offline
post #7 of 42 (permalink) Old 02-23-2012, 11:29 AM
Euchre's Avatar
Now that I've mentioned clocking, you'll be looking at all those fasteners and noticing how randomly they are all oriented...
You know you want to make them all match. You do. You know it.
The Mighty Quinn!
Euchre is offline
post #8 of 42 (permalink) Old 02-23-2012, 12:48 PM
cmill1154's Avatar
Car: 2000 Limited Wagon 5MT
I replaced the three factory ground under the hood with 4 gauge cable and copper lugs. Then added a fourth from the battery negative to the strut tower. I saw pretty good change in light dimming at idle and engine "smoothness." I plan to replace the alternator positive that runs to the fusible link. Changing that on my old truck and Subaru made the biggest difference when running lots of accessories at idle.
cmill1154 is offline
post #9 of 42 (permalink) Old 02-23-2012, 03:30 PM
LosAngelesLGT's Avatar
Car: 05LGT unltd RBP 5mt Stage3.5 359whp/425wtq + 06 OBXT BSM/GGO 5mt ltd. + 1999 Dodge Durango Modded Towpig & 19' Airstream CCD
There is nothing outstanding on the "Things the car needs serviced and/or repaired" list. But my "To Do" list is almost empty and making me twitchy. Nothing to tinker on...
I avoid touching any metal fastener...Too many have sheared off already (hate you so much rust!) during routine maintenance.... I need to replace the bolts on my washer fluid reservoir ... And drill out the bolt the snapped off on my intake. And...I hate rust.
= Maybe you should do something about the deteriorating condition of your car
NO.
Now that I've mentioned clocking, you'll be looking at all those fasteners and noticing how randomly they are all oriented... You know you want to make them all match. You do. You know it.
Cleaning, looming, powdercoating, installing, rewiring... Ah the cures for boredom.
LosAngelesLGT is offline
post #10 of 42 (permalink) Old 02-23-2012, 03:38 PM
Euchre's Avatar
Not everyone considers that kind of 'looming' pretty. You might say 'wire hiding' instead.
Have you waxed your painted engine parts? Clearcoated the bare metal? Looks like you still need to highlight the 'full' and 'low' marks on your reservoirs.
The Mighty Quinn!
Euchre is offline
