web site abnormalities - Page 5 - Subaru Outback - Subaru Outback Forums
 5Likes
post #41 of 90 (permalink) Old 04-23-2018, 08:36 PM Thread Starter
atc98092's Avatar
OK, came home and opened the same forum (Gen 5). Using the same browser (Chrome), although my work computer blocks me from logging the server into my Gmail account. Naturally, everything worked perfectly. I'll see what happens when I check one more time from a different computer at home, and then tomorrow morning when I get to work.
Dan
atc98092 is offline
post #42 of 90 (permalink) Old 04-23-2018, 09:46 PM Thread Starter
atc98092's Avatar
Went upstairs, using a different Windows 10 computer, still with Chrome. My last post here was at 5:36PM Pacific. When I opened the Gen 5 forum, there was a post from me made at 5:32PM that was shown as unread, along with 7 older threads that I had already marked read. When I opened the thread that I had posted to (https://www.subaruoutback.org/forums/...ml#post5550761 was the URL), instead of taking me to the last post (mine), it opened on the very first post. My post was the 4th (https://www.subaruoutback.org/forums/...ml#post5551273).
The two threads that actually had unread posts: when I clicked the "first new post" icon, instead of taking me to the posts that were made after 5:30, it instead opened posts from 1:20 PM (https://www.subaruoutback.org/forums/...ml#post5550617) and 1:19 PM(https://www.subaruoutback.org/forums/...ml#post5550601). The actual unread posts were from after 6PM Pacific (https://www.subaruoutback.org/forums/...ml#post5551369 and https://www.subaruoutback.org/forums/...ml#post5550601).
I hope this is enough detail to give some clues to what's happening. As a reminder, I have switched back to the default forum theme.
Dan
atc98092 is offline
post #43 of 90 (permalink) Old 04-25-2018, 05:50 PM Thread Starter
atc98092's Avatar
Well, after two days of testing, it was looking fine, until I came home this afternoon. The last time I marked the forum read was just before 1PM Pacific on my work PC. It is now 2:36, and I'm home. Same browser (Chrome), but when I open the forum I find "unread" posts back to 9:32AM this morning, for a total of 10 messages.
Only four were actually unread. But even when I opened the ones I knew contained unread posts, three took me to posts I had marked read earlier this morning, while one took me to the only new post.
Every time I use the "Mark Forum Read" function, but I can reload the page after I do that and it will sometimes still show unread messages, including my own posts.
I see four other auto sites that are owned by this company that I have used in the past or continue to use (PassatWorld, ClubTouareg, Fourtitude and VWVortex) and have never encountered this before. In addition, I use TDIClub, AVSForums, Roku and Serviio forums (admin of Serviio) and it doesn't happen with them either. It's certainly puzzling...
Dan
atc98092 is offline
post #44 of 90 (permalink) Old 04-27-2018, 10:49 AM Thread Starter
atc98092's Avatar
OK, here's a real puzzlement. Working from home today, so have access to more than one PC at the same time. Read the forum on my work laptop and used the Forum Tools to mark the forum as read. Reloaded the page on the same computer, and it shows only two unread threads that were just updated. Perfect.
Open the forum on my home computer. This was about 10 minutes after I marked the forum as read. It shows everything unread as if the work computer had never connected. I just again marked everything as read with the work PC. Refreshing the page on the home PC still shows over two dozen unread threads. The work PC shows the entire forum as read.
Dan
atc98092 is offline
post #45 of 90 (permalink) Old 04-27-2018, 11:10 AM
Administrator
administrator's Avatar
That is how it's supposed to work. The site uses Cookies to track what you have and have not read. Some of the sites in our network that you use track by marking in the Database, so that no matter what computer you check from, your viewing history remains intact.
I can change it, but it would change it for everyone. Would need some feedback before doing such a thing
Kevin
Test
administrator is offline
post #46 of 90 (permalink) Old 04-27-2018, 01:48 PM
Feedback Score: 11 reviews
I'm good with that change if it will more accurately show which threads have been read (up-to-date). But will it affect anything else?
plain OM is offline
post #47 of 90 (permalink) Old 04-27-2018, 03:46 PM Thread Starter
atc98092's Avatar
If it was browser specific, as I would expect cookies to be, that doesn't explain why the same computer using the same browser still has issues. But in any case, I would be all in favor of the system recognizing my read threads and carry that information across different browsers and computers. As I've said, I've never encountered a forum that did it this way before, which is why I brought it up in the first place.
But plain OM has a valid question: would it cause any other change to the user environment? I can't think of anything that might, but then you know your software better than I do.
Dan
atc98092 is offline
post #48 of 90 (permalink) Old 04-27-2018, 03:56 PM
Administrator
Hey there,
It shouldn't change the user environment. It'll pretty much just help with marking forums read.
Any more feedback? Will need a bit more before I go ahead and flick the switch on
Ed
Test
post #49 of 90 (permalink) Old 04-27-2018, 07:42 PM Thread Starter
atc98092's Avatar
It's strange that I can switch browsers and the threads remain marked as read, even on different computers. It's just so random that it happens sometimes, and other times the same browser on the same computer doesn't keep track. I think turning it on from your end would resolve the issue.
Turn it to 11!!!
Dan
atc98092 is offline
post #50 of 90 (permalink) Old 04-30-2018, 01:20 PM
Administrator
It could be that there are some glitches with your account. Changing the method we mark as read might clear up for you.
Just to correct Ed, there is one change that would occur. The "New Posts" page would behave a little different. Threads that are "read" get removed from that list instead of just marked as read. If you choose the specific date ranges, (last day, 2 days ago, etc.) then you get around that quirk.
Tagging in some mods for input.
Kevin
Test
