Unknown noise coming from rear end. - Subaru Outback - Subaru Outback Forums
 2Likes
post #1 of 21 (permalink) Old 04-25-2019, 08:06 AM Thread Starter
Specialized29er's Avatar
Car: 2004 Subaru Outback Station-wagon and a 2002 Holden Commodore sedan
Have a 74,000 k Outback and its starting to develop a strange noise that seems to be coming from the rear end.
Wondering do the 2004 Outbacks have a common fault involving the rear end. On Wednesday we took the Outback for a 800 klm drive and all seemed well, drove beautifully. This morning when going to the dawn service we hopped in and noticed the noise when cold and seems to be less of a noise after 10 klms.
I'm thinking its a bearing but whats strange is that's its only done a gentle 74,000 ks.
Anyone in the know or might have experienced such a noise.
Step right up, chum, and watch the kid lay down a rubber road right to freedom!
Specialized29er is offline
post #2 of 21 (permalink) Old 04-25-2019, 08:48 AM
time takes its toll as well as miles. rubber and grease breaks down, rust creeps etc.
has the timing belt system been serviced? if not, it's a ticking time bomb.
can you describe the noise?
1 Lucky Texan is online now
post #3 of 21 (permalink) Old 04-25-2019, 08:59 AM
scalman's Avatar
Car: Outback 2001/11 . 2.5AT . VDC .
I have it too but i think maybe its my tires because i changed bearing changed axle and nothing changed still wining when going more then 80 km/h and after 100km speed steering starts vibrate.
All wheels done balancing, alignment. So what else left ? Why vibrate at higher speed. ?
Heard that axles can do vibrating too but how to know which one?
OBW '01 / H4 SOHC 2.5 / 4EAT / VDC / rear LSD / LPG conversion / 2'' top strut spacers lift / BFG TA KO2 215/65 R16 /GC - 10.2''/26cm
both sway bars removed
scalman is offline
post #4 of 21 (permalink) Old 04-25-2019, 07:10 PM Thread Starter
Thanks guys, I'm thinking I'll start with the rear hubs and have the axles rebuilt and then if the noise is still there then its gotta be the differential.
2,000 ks ago we had new genuine 5 spoke rims fitted along with a set of the Yokohama Geolander All Terran tyres and no noise until a couple of days ago so that rules out the tyres.
Noise is coming from the rear and when cold it sounds like a humming/whiring noise and once the mechanical's are at normal operating temperature it quietens down.
The sound isn't bad so I'll jack it up and put on stands and get started on her before the 6 hot months come a knocking.
Yes am aware of the timing belt wear they develop and have a Gates replacement kit for when that day comes the belt and assembly needs replacing, have looked up the procedure on YouTube and it looks straight forward. At the same time I'll have the radiator tested and replace the heater and radiator hoses.
post #5 of 21 (permalink) Old 04-25-2019, 07:42 PM
eagleeye's Avatar
when was the last time you checked the rear diff?
when was the last time it was drained/ filled?
what grade lube is in there. ?
any chance its got some water in it from being driven though some (like streams/ beaches/ flooded road / boat ramp)
eagleeye is online now
post #6 of 21 (permalink) Old 04-25-2019, 08:22 PM Thread Starter
I've only had the car for a year and before that my Mum owned the car and only drove it to church, indoor bowls and grocery shopping.
In the time I've had the car I've only driven it to take Mum to the Doctors, shopping, nothing rough, no off road and no water.
Except for replacing the fuel tank/pump and filler neck all I've done is service the engine and transmission, upgraded the audio and changed over to LED headlights.
I haven't checked the differential oil but was thinking of doing this once its jacked up and on the stands, never know if might be low but do doubt that since the car has only ever been serviced by Subaru every 10,000 ks.
Name:	Subaru - 2004 25.04.19.JPG
post #7 of 21 (permalink) Old 04-26-2019, 07:07 AM
Car: OBW H6 VDC, Tribeca, XT6
check the brakes for hung up debris or pads hanging against the rotors somewhere or very minor changes in the noise before/after braking.
wheel bearing.
driveshaft carrier bearing or ujoints are culprits too but the ujoints would produce vibration rather than noise, or both.
idosubaru is offline
post #8 of 21 (permalink) Old 04-26-2019, 08:34 AM
cardoc's Avatar
Before you start taking things apart, get all the wheels off the ground and with the car in Neutral check for vertical play in the wheel assemblies by grabbing the top and bottom of the tyre at the same time and try to move it. If there's no movement, put one hand on the strut spring and spin the wheel with the other and feel for vibration. If there's vibration traveling through the strut, or one of the control arms, then the bearing is worn.
While it's up, and if it's up high enough to roll under the car, if you have a helper have him/her put the car in gear and let it roll idling and get under there and listen for noise from the rear diff. I don't believe you'll have any. It would be a great idea to change the rear diff fluid. Every 30k miles tops.
cardoc is offline
post #9 of 21 (permalink) Old 04-26-2019, 08:42 AM
scalman's Avatar
what if i changed rear bearing on one side and axle on same side and its still whining when getting to more speed .coud it be tires just when they worn out some now and become just more noisy ?
but i tried changed rear tires to front ones and its still same sound from rear and not front.
changed rear diff oil about month ago too. so whats left ?
scalman is offline
post #10 of 21 (permalink) Old 04-26-2019, 09:30 AM
is the noise central or from the corner?
sit in the back....i've even sat in the trunk area once with my head to the floor to verify it was the corner (ended up being wheel bearing)
you should be able to tell if the noise is coming from the corner or centrally located.
does it sound like a bearing? or could it be rubbing?
has it always had this noise since you owned it or it?
did it start after any work?
was this car ever in an accident?
noise coming from drivetrain .... hard to record zero7404 Gen 5: 2015-2019 0 05-10-2018 04:38 PM
Rear End Noise / Right Hand Turns kkjellquist Gen 2: 2000-2004 10 12-30-2015 07:07 AM
Noise from rear end of an H6 TrekLawler Problems & Maintenance 15 02-19-2014 11:45 AM
Rear End Creaks! jp1203 Gen 2: 2000-2004 11 10-19-2012 10:42 PM
Please Help Diagnose Rear End Humming Noise bflatt Problems & Maintenance 3 11-29-2010 09:09 PM
