Speaker problems - Subaru Outback - Subaru Outback Forums
 3Likes
  • 1 Post By mprosco91
  • 2 Post By KingBing
post #1 of 5 (permalink) Old 01-24-2019, 08:08 AM Thread Starter
Angry Speaker problems
I have a 2018 Outback, which a complete failure of the infotainment center, which was replaced. Ever since, the speakers have not worked well. The driver side front speaker is the only one which works all of the time. The center speaker is mostly not working, but randomly works for maybe a minute at a time. The other speakers work, but at a much lower volume. Has anyone else had this problem, and do you know how to get it fixed? I have had it in for service and they said they could not find a problem. Told me they were working, but as soon as I got in the car I knew they had not solved the problem.
Barbara Shull is offline
post #2 of 5 (permalink) Old 01-24-2019, 08:38 AM
you may need to get SOA involved. If possible, find a piece of music that illustrates the problem well and have the service writer listen in you car and then compare to a different car on the lot?
1 Lucky Texan is offline
post #3 of 5 (permalink) Old 01-24-2019, 08:59 AM
Doug Just Doug's Avatar
Car: 2016 Outback 3.6R Ltd. w. Eyesight
Assuming your balance/fade settings are correct, I'd call SOA as advised above. Could be a bad replacement head unit, or perhaps the tech who replaced the unit did a poor or partial job re-connecting the speakers.
Current Garage:
2012 Honda CRV 4WD EX
2008 Honda Fit Sport
2015 Kawasaki Versys 650
1986 Schwinn Sierra MTB :^)
Doug Just Doug is offline
post #4 of 5 (permalink) Old 01-24-2019, 09:09 AM
This.....or when the head unit went bad it killed the amp as well. Older models used to be under the passenger seat. Not sure if that's still their location
Sent from my SM-G955U using Tapatalk
Doug Just Doug likes this.
mprosco91 is offline
post #5 of 5 (permalink) Old 01-24-2019, 09:21 AM
KingBing's Avatar
Car: 2018 Outback 2.5i Limited; Green/Ivory; Eyesight; Navigation
This all depends on the trim level of the Outback. The speaker connections may either be at the head unit or they may be at the amp.
A little more information and investigation would be needed. Either way, I'd keep hounding Subaru about it. Either back to the dealer or calling SOA. I'd most likely do the latter and then the former.
Doug Just Doug and mprosco91 like this.
KingBing is offline
HK System Speaker Replacement- Sub/Amp Addition pduncan Gen 5: 2015-2019 26 03-07-2019 02:24 PM
Overrated problems skullone Gen 4: 2010-2014 26 07-20-2013 07:48 AM
Problems with starting up after a rainstorm RobbBlack Problems & Maintenance 5 06-28-2013 09:31 AM
2001 Outback problems, problems, problems! Wilk884 Problems & Maintenance 6 12-15-2012 09:47 PM
2003 Outback Speaker Problems coz375 Electrical & Electronics 8 12-05-2012 07:34 AM
