front suspension clunk - Subaru Outback - Subaru Outback Forums
post #1 of 8 (permalink) Old 05-15-2019, 01:45 PM Thread Starter
unit5alive's Avatar
Car: 2008 outback ltd 2.5 vdc pzev,Limited Slip rear axle
Hi guys I've got a front suspension clunk that sounds like a upper strut mount or swaybar end links,the swaybar end links front and rear are new subaru parts , I was posting to see if there are any parts or bushings ,ball joints etc that commonly go bad on the front suspension , the car is a 2008 outback with 113,000 miles, it seems to make the noise going over patched up road surfaces the most.
2008 subaru outback ltd , vdc
2004 ford f350 lariat
2013 mustang boss 302
1990 mustang lx 5.0l
honda mini trails,76z50,74ct70
2003 Harley Davidson fatboy
schwinn phantom,97harley bicycle
07kawasaki mule610,Kubota BX backhoe
unit5alive is offline
post #2 of 8 (permalink) Old 05-15-2019, 02:14 PM
have you inspected under the car?
sway bar mounts, rear bushings on the front lower control arm...11 year old car could have just about any steering or suspension part worn-out.
1 Lucky Texan is online now
post #3 of 8 (permalink) Old 05-15-2019, 02:23 PM Thread Starter
unit5alive's Avatar
I did look a few weeks back and did not see anything suspect,everything looks ok,swaybar mounts are good energy suspension mounts, thats why i was posting to see if they are known for control arm bushings for an example, i just hate to throw parts at things , the lower control arms are $215 each and strut mounts 80 each ,for subaru parts .
post #4 of 8 (permalink) Old 05-15-2019, 02:37 PM Thread Starter
unit5alive's Avatar
The car had been great till it hit 105,000 miles ,had the head gaskets done with all the seals ,valves adjusted ,belts,water pump ,and misc gaskets ,the a/c quit around 100k also,no complaints the car has been awesome all except for the exhaust heat sheilds,lol
post #5 of 8 (permalink) Old 05-15-2019, 02:53 PM
Car: 2005 Outback R LL Bean 3.0 H6 w/ 5 speed sport shift
I would put it on jack stands then use a jack under the tire/hub to lift ever so slightly and observe to see if you can see anything moving in the suspension that doesn't look right. Check the lower ball joint since the retaining bolt is a weak point where the threads can strip and the joint can move. My gut says strut mounts.
While you have the wheels off the ground, give them a wiggle test (side to side & up and down) to see if you could have a bearing assembly going bad.
Evil Soob is online now
post #6 of 8 (permalink) Old 05-15-2019, 03:28 PM Thread Starter
unit5alive's Avatar
I did check the bearings as you described,and the ball joints,when i did brakes and rotors a few thousand miles ago.
post #7 of 8 (permalink) Old 05-16-2019, 07:41 AM
MyNameIdeasWereTaken's Avatar
Car: 2014 Outback 2.5i Manual
You have new endlinks, have you checked that they're securely tightened?
his |
hers |
his |
hers
Previous:
MyNameIdeasWereTaken is offline
post #8 of 8 (permalink) Old 05-16-2019, 08:20 AM Thread Starter
unit5alive's Avatar
Yes i re checked the torque on them twice and they are subaru end links, it sounds like end links or upper strut mounts, i have to dig into it i guess.
Top Safety Picks for 2019 airbi News & Media 0 12-20-2018 08:06 AM
05 Outback Noise front end/ suspension - Groovy2 Wheels, Tires, Brakes, & Suspension 1 07-19-2015 05:34 PM
2011 Outback Front Suspension Clunk/Rattle/Clack Lab Rat Gen 4: 2010-2014 11 11-25-2013 02:54 PM
Outback: 2000, 130K, 2.5 front suspension tapping zxj24 Gen 2: 2000-2004 1 02-25-2013 10:47 AM
Endlinks? finneys98xj Gen 1: 1995-1999 7 03-10-2012 02:13 PM
