Brake job issue on 2015 Outback (also fuse problem?) - Subaru Outback - Subaru Outback Forums
 1Likes
  • 1 Post By skipw
post #1 of 5 (permalink) Old 05-25-2019, 03:15 AM Thread Starter
So I did a brake flush and brake pad change on my 2015 Outback. Had no issues and everything seemed to go fine. Afterwards the brakes felt good but there is an audible 'whooshing' sound (inside near the pedal) when depressing the brake pedal far past the brake's limits. Usually done when sitting still. The brakes are very crisp and firm when moving though, and do not seem to have air in the lines. Prior to doing this there was no whooshing sound, so I assume something is wrong.
I also can no longer roll down the passenger side window with just the driver's controls. Just the front passenger window. Do I need to change a fuse here? I'm guessing disconnecting the negative battery terminal prior to brake flush might be the cause here.
Any ideas?
Mk23 is offline
post #2 of 5 (permalink) Old 05-25-2019, 07:36 AM
AbsoluteZero's Avatar
Car: 2016 Tungsten Outback 2.5l Premium w/ES, OP 14, PP #4
Try this:
Initialize the power window in the following procedure to reactivate such functions.
1.Close the driver’s door.
2.Turn the ignition switch to the“ON” position.
3.Open the driver’s side window halfway by pushing down the power window switch.
4.Pull up the power window switch and close the window completely. Continue pulling up the switch for approximately 1 second after the window is closed completely.
AbsoluteZero is offline
post #3 of 5 (permalink) Old 05-25-2019, 10:09 AM
Car: '15 Outback 2.5i Premium
Originally Posted by AbsoluteZero View Post
Try this:
Repeat this procedure from the passenger seat using the passenger's window switch to reinitialize that window (also do this for any other windows that have one-touch automatic open/close).
Biebs likes this.
skipw is offline
post #4 of 5 (permalink) Old 05-25-2019, 04:17 PM Thread Starter
Try this:
Thanks so much! I'll definitely be giving this a try.
Any ideas on the brake pedal noise?
Mk23 is offline
post #5 of 5 (permalink) Old 05-26-2019, 02:33 AM Thread Starter
So I just realized (after a bit of googling) that it is possible something may be wrong with the brake booster (which is near the brake pedal and works via vacuum).
Is there any way to reinitialize or reset the brake booster? Is it possible my brake booster is bad?
Edit: Found a video of the exact same issue:
Mk23 is offline
Brake Bleeding 00 Subaru Outback Base with ABS SATEXASSUBARU Gen 2: 2000-2004 3 01-27-2018 07:35 PM
2011 2.5i Subaru Outback DIY Brake Job jvaski Do-It-Yourself Illustrated Guides 12 05-16-2017 02:23 PM
2015 Outback display glare problem halotree Electrical & Electronics 10 08-18-2016 07:09 PM
Thanks and will miss my 2006 Subaru Outback XT imdakine1 General Discussions 6 08-19-2014 11:52 AM
OBXT Production Numbers KingTito Gen 3: 2005-2009 6 07-17-2013 05:50 PM
