Back when I had my VW, you were able to change your DRL to whatever you wanted, or just have them turned off completely, via VAG-COM. With my '08 Outback, is there a way to change them from the high beams to the fog lights?
Well, there is no way to do it via software, but it has been done. Keep in mind that they changed the wiring configuration for the '07 and up DRL circuits, so I don't know if this is accurate or not for your application, but this should give you a place to start..
I'm just looking for clarification on wire colors, the circuit seems simple enough. I've already unplugged the resistor to disable DRL just need to know which wires to tap, I suppose I could do my own research and pull the diagram *sigh*
188.8K members
