Amp Install - Subaru Outback - Subaru Outback Forums
 1Likes
post #1 of 12 (permalink) Old 04-11-2019, 08:54 PM Thread Starter
Amp Install
Iím hoping that someone can shed some light on some questions that I have about installing a aftermarket amplifier. Iíve searched throughout the forum and have not found these answers.
I own a 2011 Subaru Outback with the Harmon kardon factory amp.
Iíve been trying to figure out where to splice in with a line out converter.
I think that I have the proper wiring diagram (thanks to crutchfield). I want to remove the hk factory amp but when I started my car I began pulling the plugs from the back of the amp and in order to hear sound from the radio they all had to be plugged in.
Can I just unplug it and tap my line out converter into the harness that has the speaker wires or can I splice into the plugs while keeping the hk amp still plugged in?
If I have overlooked a thread I apologize but Ive spent considerable time trying to figure this out and am at my wits end.
Thank you thank you thank you
Insectazor is offline
post #2 of 12 (permalink) Old 04-11-2019, 11:26 PM
paging user @botenredwolf
1 Lucky Texan is offline
post #3 of 12 (permalink) Old 04-12-2019, 12:22 AM
botenredwolf's Avatar
Car: 2010 Legacy 3.6R Limited || "1SlickVDC" 2001 Outback H6 VDC
Can I get a copy of that? I'm working blind on mine.
I just typed up a whole bunch of shite about integrating with the HK amp and aftermarket head unit because I don't know how to read. lol
Okay. Before I start taking my car apart, let's make sure we're on the same page, you have:
All factory system, including head unit, amplifier, and speakers for the Harman/Kardon system with built-in Bluetooth.
You want:
Factory head unit and speakers but aftermarket amplifier (and I'm assuming a subwoofer).
Eek. Model numbers and expected layout, like what's hooked to what from a logical standpoint? I can help you figure out specifics in a bit.
Kenwood DMX7704S + iDataLink Maestro, Stock H/K speakers and amplifier. (Not hooked up yet: Hertz Energy component speakers, JL 12W6v3 HO Wedge, JL XD1000/5v2)
botenredwolf is offline
post #4 of 12 (permalink) Old 04-12-2019, 07:13 AM Thread Starter
This is what I received from crutchfield. I’m hooking up a Kicker ZX300.1 amp to the factory radio. This amp is going to power two 10” kicker comp subs in a potted box rated at approx 300 watts rms.
My main thing is can I just unplug the factory amp and splice into the harness that connects between the headunit and the amp or should I splice it in somewhere else?
post #5 of 12 (permalink) Old 04-12-2019, 07:57 AM
cardoc's Avatar
Maybe it's just my simplicity thinking, but why not just use the factory subwoofer sound cables to feed the sound to the new amp, then run speaker cable to the new subwoofers from the Kicker amp? The subwoofer speaker cable would be powered by the factory amp, then amped up by your aftermarket amp to feed the new sub. Or splice in to the low side of the factory sub and jump it over to the new amp to feed the Kicker speakers if all you're looking for is more low end bass.
This would keep the HK amp energizing the speakers and factory sub so you still get the midrange at the rear and your new amp energizing the new box with the lows. As long as you get a good ground on the amp it should give you clarity and all you do is dial the new amp in to blend it.
botenredwolf likes this.
cardoc is online now
post #6 of 12 (permalink) Old 04-12-2019, 08:49 AM
stevenva's Avatar
Car: 2005 Outback Wagon 3.0 L.L. Bean
That model Kicker is a mono sub amp which has speaker level in as well as RCA in. Leave the HK amp hooked up. Use the subwoofer wires from the HK factory amp as the input signal to the Kicker.
RIP 96 Legacy 2.2 Thanks for 380,000 miles. (4EAT lost reverse)
stevenva is offline
post #7 of 12 (permalink) Old 04-12-2019, 10:58 AM
I second cardoc, he's right on the money there. Similar to what I did except I have an aftermarket head unit. I'm currently only using my amplifier to power the sub until I can finish installing the wiring for the mains, but the factory HK stuff is quite potent, and I do much enjoy the lower midbass/bass provided by the rear deck woofer, with my JL being able to be crossed over very low for ultra clean deep/low-bass.
post #8 of 12 (permalink) Old 04-12-2019, 04:56 PM
stevenva's Avatar
@Insectazor
If it's not too late consider an amp from Audio Control. They have an adjustable circuit which will compensate for low frequency rolloff as volume increases. Very good to have if upgrading system while keeping factory radio. If you want a 300W look into Audio Control ACM-1.300. They are compact.
stevenva is offline
post #9 of 12 (permalink) Old 04-12-2019, 05:16 PM Thread Starter
So if you havent guessed by now...i'm a newbie when it comes to car audio install.
Sound like i will keep the hk factory amp plugged in.
I will tap into the sound cables from the factory subwoofer. (using the loc?)
Any of you have pictures of what you've done when installing your subwoofer and amp?
Thank you for your help so far.
post #10 of 12 (permalink) Old 04-12-2019, 05:24 PM
stevenva's Avatar
You do not require a Line Output Converter in your case. Only if your amp is RCA input only, which it is not. You will simply be using the speaker level inputs which your Kicker has, to the factory sub speaker wire.
stevenva is offline
2009 HK Amp and Radio ? leeleses Electrical & Electronics 1 05-27-2016 02:54 PM
FS: Alpine GPS/Audio Head Unit INE-W927HD + Install Kit (Santa Cruz, CA) J Delman Classifieds 2 07-06-2015 12:34 PM
Borla Header install time? thebigd1973 Parts, Accessories, & Performance 2 10-02-2012 06:06 PM
(CA) FS: JVC Head Unit/JL Audio Amp Amz Classifieds 0 07-25-2012 10:52 PM
2005 Outback Custom Amp/Sub Install blondy Audio, Video, Security, & Navigation 9 05-19-2010 05:51 AM
