Why wheels? - Subaru Outback - Subaru Outback Forums
 1Likes
  • 1 Post By tddockery
post #1 of 10 (permalink) Old 05-19-2019, 11:59 AM Thread Starter
Car: 2018 Outback 2.5i
Question Why wheels?
I'm just wondering if there's a good reason to change the wheels on my stock '18 2.5i.
I get changing for looks. I'm planning to get A/T tires. Is there a problem with the stock wheels and A/T's?
At some point I'll probably lift the car, but for now tires and skid plates are first.
Thanks!
Dave
Some days...
It just isn't worth chewing through the leather straps
2018 Outback 2.5i
Crashed is offline
post #2 of 10 (permalink) Old 05-19-2019, 10:52 PM
johnkjos's Avatar
Car: 2018 3.6R Outback Touring
The main issue is that bigger A/T tires may rub on suspension components. That's why almost all aftermarket wheels have a smaller offset. My factory wheels have a 55mm offset. Most aftermarket wheels that I've seen are in the 35-42mm range. If you install larger A/T tires you can install spacers to avoid the contact problem. I did that. Installed Perrin 20mm spacers.
johnkjos is offline
post #3 of 10 (permalink) Old 05-20-2019, 09:18 AM
As far as the offsets go it depends on how big of a tire you're talking. I run 235s on stock rims with no problems and may have posted about having 245s without rubbing.
Ls1BadBird is offline
post #4 of 10 (permalink) Old 05-20-2019, 09:51 AM
Brucey's Avatar
Car: '17 3.6 Limited
245/65/17 doesn't rub on stock wheels but it will on some aftermarket wheels.
Brucey is online now
post #5 of 10 (permalink) Old 05-20-2019, 03:41 PM
johnkjos's Avatar
The original post stated that one of his next steps would be to install a lift kit. If you're going to do that I would assume that significantly larger A/t tires would be the choice. I've also read in this forum that even 255/55R18 tires fit without rubbing and without a lift, but no doubt on wheels with something like a 35mm offset or with spacers on stock wheels.
johnkjos is offline
post #6 of 10 (permalink) Old 05-20-2019, 06:32 PM
SuperRu's Avatar
Car: 2019 3.6R & 04 FXT
One reason we changed our wheels was to reduce weight. The new Enkei PF01's are 17.8 lbs compared to about 25lbs for the stockers. Reducing tire and wheel weight is good for braking, acceleration, and ride quality etc..
Admin @ SubaruForester.Org
His...
Her...19 OB Limited 3.6R
Spare...98 Forester S
Daughter...07 OB
Dad...19 OB Limited 2.5
Sister...98 OB
Brother...19 Crosstreck Limited
Brother...17 WRX & 18 Impreza
SuperRu is online now
post #7 of 10 (permalink) Old 05-20-2019, 06:42 PM
tddockery's Avatar
Car: 2008 3.0R LL Bean in Deep Bronze Met.
Personally, I prefer the design of the OEM 18" wheels on my 3.6R
I now have a 2" lift installed, but even before there were no rubbing issues with the 235/60/18 Geolandar G015 A/T tires I am running.
Here are 'before lift' and 'after lift' pics, both on the 235 G015's...
ID:	452649   Click image for larger version
Brucey likes this.
2016 3.6R in Lapis Blue over beige leather. Rear Bumper Cover, JDM wheel well trim, 235/60/18 Geolandar G015's, Rage Powersports Safari Basket, Full size roof mounted spare, Auto dimming side mirrors, Rear Bumper Underguard, Remote Start, Seat Back Protectors, Draw-Tite Max hitch....
tddockery is offline
post #8 of 10 (permalink) Old 05-20-2019, 07:02 PM
Brucey's Avatar
I like the blue. Good looking ride!
post #9 of 10 (permalink) Old 05-20-2019, 07:57 PM
tddockery's Avatar
Thanks Brucey!
I originally wanted Wilderness Green, but I couldn't find a low mileage CPO 3.6R with ES when I stumbled on this.... admittedly, the blue is definitely growing on me 🙂
post #10 of 10 (permalink) Old 05-21-2019, 09:17 AM Thread Starter
I've wondered what the stock wheels weigh. I've been paying attention to weights while I've been window shopping. I like the idea of less rotating mass.
Dave
Some days...
2018 Outback 2.5i
Crashed is offline
The I Put Wheels From Tire Rack on my 2019 and Got TPMS to Work Thread GrumpySquatch Gen 5: 2015-2019 42 05-02-2019 12:22 PM
Parts department had no clue on wheels??? Rocksister Wheels, Tires, Brakes, & Suspension 3 07-20-2015 12:43 PM
FS: Prodrive wheels Rittmeister Classifieds 1 07-05-2015 02:22 PM
Upsizing Wheels - effect of offset on performance duncaroo Wheels, Tires, Brakes, & Suspension 9 12-07-2012 04:03 AM
winter wheels harrydog Wheels, Tires, Brakes, & Suspension 4 11-28-2005 07:59 AM
