'00 & '01 OBW 2.5, AT, '95 jeep yj with galvanized frame, detroit locker, Super 35 axle kit, 4.88 gears, 2.5 5spd, 1964 Austin Healey Sprite basket case that will someday be subie powered
Hi guys! So- upon repairing my deer damaged OB, I decided to replace the way leaky drivers side front cam seal. The culprit seems to be a broken tension spring around the back side of the seal. I bought a new seal from Napa, and there is an o-ring in the box, along with my seal. I didn't remove an o-ring from the car, nor do I see one inside the front camshaft. Is it for the rear? Its slightly larger than the seal. It is a sohc 2.5.
