1 - 2 of 2 Posts
2001 Outback 2.3 4 cyl
I have a 01 OB 2.5 5sp. I have had issues with the clutch intermitantly engaging. Replaced clutch, master and slave cylander, flywheel, throw out bearing, and still nothing. Someone said it could possibly be the syncros in the transmission... I need help.
There are so many options here. Is it slipping or not engaging? Is it grinding on engagement? Have you checked your axles and differential?
1 - 2 of 2 Posts
