01 H6 Outback, just died last week. Nimrod chevy mechanic tore off crank cover: timing chains, guides and tensions look great, timing in sync. Ran compression tests in all 6 cyl, with cover off, got some pretty low numbers on the the driver side.
Buttoned it all back up, check plugs for fire; thier good.
Changed out fuel pump, didnt look too close at the O-ring (may have to pull it out again).
Engine will fire when the air intake is blocked (piece of cardboard over it), but not on all cyl and dies as soon as it gets air.
At only 180K I find it hard to believe that I threw a valve or a set of rings. I've been the only onwer and have been relgious on maintainence.
Any input or ideas would be appreciated.
