1 - 9 of 9 Posts
Hey guys I have a 2001 Subaru Outback 2.5 automatic, it's been great all up until three days ago,the car had a hard start and the idle is a little tougher, when put in drive it will coast forward but as soon as I put pressure one the gas pedal it seems to chug and bog down, sometimes even shut down. It's not throwing a cel. I still plugged in the coder and it's showing problems with o2 sensors, cat, hrt and evap. Any suggestions??
how old is the battery?
how long since a timing belt system service?
any work, wrecks or offroad adventures before this began?
I think vacuum gauge testing might be a cheap easy thing to try. check on-line and youtube videos for what to look for.
cat is probably P0420 - it will likely go away when other stuff is fixed. it best to post actual codes for us.
that looks like monitor readiness but, I'm unfamiliar with that reader.
we would prefer to see actual DTCs like; P0420, P0440, etc.
maybe check the instructions more closely to see if there are other 'pages' or modes to display?
also, hfarthington mentioned fuel, try spraying starter fluid into the intake while cranking/idling. If it runs better, fuel likely an issue.
Also, perhaps check the fuel pump for a ruptured o-ring; http://www.subaruoutback.org/forums/110-gen-2-2000-2004/41182-symptoms-fuel-pump-o-ring-problem.html
any other lights on? battery or ABS or brake, etc. ?
Reactions: hfarthington
I know that Engine Coolant Temp sensors can cause hard starting. Best to see if their are any PXXX codes stored before changing parts
1 - 9 of 9 Posts
