I noticed my car has been leaking small amounts of coolant, Ive had it pressure tested and they said everything check out.
The other morning after running the heater on my way to work I noticed it leaking quite a bit of coolant after I parked my car. I looked underneath to check it out and there was coolant on the cooler lines on the opposite side of the oil filter and also noticed coolant dripping from the weep hole.
When I run my car without the Heater on there is a lot less coolant leaking.
I am curious if this is a water pump issue or maybe problems with the Heater core lines?
If it is leaking coolant through the weeping hole is it for sure the Water pump?
Any comments or links to more info is very appreciated.
Thank you.
Thank you.
