I am looking to add some footwell lighting to my Baja. I want them to come on when the door opens, but I am also going run them through with the dash lighting and have a separate switch, which would allow them to be dimmed. Any thoughts on power sources I can tap into? For the door open/close power source I am not sure where to look. For the dash lighting power source, I am not using the wire designated for the radio illumination since mine is aftermarket. I am assuming the wiring is similar to an 03 outback as well
