21 - 40 of 66 Posts
will this work on my 06 WRX?
Good question. The original post is based on information in the Outback/Legacy FSM. Perhaps someone here has the equivalent FSM for the Impreza-based cars (assuming the WRX would share at least this aspect).
The 2010 Forester FSM has a self-reader for DTC's (see attached) that looks similar if not identical (haven't checked it closely). I would presume therefore that the 2006 probably had the same.
Worth a try . . . .
03 H6 OBW & 06 WRX Sportwagon
I'll try it on my wrx, maybe after work or this weekend.
tried it a coupla times in my 06 wrx, no change. My scanner connects with the IWP protocol. wondering if only CAN cars have this self diag feature?
19 Limited/20 Onyx (7TH)
very cool! Just tried it with my 08 OB, auto, and A/ P----
B/ just kept blinking
C/----
as stated in the original post maybe nothing for B to report.
turned key off and then started and it went back to normal display. Worked on first attempt.
Lawn ornament XT
The first post lists this as working for '05-'09, but a few folks with '05s have tried it without success. I've never seen anything official that said which cars had the capability and which didn't. Nothing to lose by trying it.
I just re-skimmed this thread, there is a link in ghghhghg's post which lists a different procedure for the '05- try that?
2017 Touring 2.5i; '07 B9T Ltd, '04 Forester X
It seems to work on the 2007 Tribeca; however, while the ECM and TCM aren't throwing any codes (just getting P----), the VDC is throwing the following DTCs:
C0744
C0251
C0421
Not one of these DTCs appears in the FSM (VDC pages attached), or anywhere else online for that matter (at least in the places I can access); however, I noticed that if you replace the '0' with a '4', you will find C4744, C4421 and C4251 listed as "Detailed Codes" in the FSM.
That said, "744" is also the first part of the VIN key for the '07 Tribeca, but 251 and 421 have no apparent connection to my VIN, so I'm not really sure if I'm actually looking at chassis codes or if I'm seeing something completely different (maybe an ECM serial number).
2011 Legacy 2.0L
To psygnal11! your P code is empty probably because you don't have anny trouble with your engine.
C codes are mented to ABS and/ or another electrical parts into your car.
Yes, I understand that there is no problem with my engine or transmission... my question relates to the fact that my Tribeca is throwing C codes that are not defined in the service manual.
2011 Legacy 2.0L
I would ask my Subaru dealer what this code means? Otherwise you may ask to companys who repair cars after an carcrash. Possibile is this code related to the airbag module.
C0251 appears to be electronic parking brake for newer cars?????
based on a very quick search
SRS/Airbag codes are 2-digit codes, which to my understanding, cannot be read by anything or anyone without the Subaru Select Monitor. I'm 99% certain these are VDC codes (as the sequence is ECM, TCM, VDC/ABS); however, I've checked every DTC table in the FSM to no avail.
Lawn ornament XT
I don't know any of those codes myself... Have you tried looking in the FSM for any other VDC-equipped models?
I've looked in the 2007 Legacy FSMs (USDM and JDM), but I can't find anything remotely similar.
I think what I might do is open the brake lamp circuit by pulling or covering one of the pins on the pedal switch to see if I can induce it into throwing a code. C0054 is the DTC for an open brake lamp switch and 4541 is the only detailed code. If my "replace the 0 with a 4" theory is correct, I should see C0541. If not, back to square one.
UPDATE 3/20 -- I didn't have a chance to "induce" a C code yet, but I recalled that VDC/ABS codes are stored indefinitely until cleared with the SSMIII. So on a whim, I pulled the CarFax report from when I bought the car last October and noticed that in Jan 2012, there is a dealer service record described as "Wheel speed sensor(s) replaced/repaired, Electrical system checked"
4251 happens to be the detailed code for the FL wheel speed sensor signal system.
4421 is the detailed code for a power voltage malfunction.
Inducing a C code or two should confirm it, but so far the evidence seems to be backing my "replace the 0 with a 4" theory.
has anyone had success reading codes on a 2005 outback using this method?
Nope. Just tried on my '05 outback XT.
Checked in fuse area of drivers seat, I see no such connection. I didn't remove any kick panels but I don't see it. If it's taped and wrapped possibly in wire loom I wouldn't have seen it though.
2005 legacy wagon
Image of fusebox for Self Diagnosing 2005 Legacies with M/T
2005 Legacy 2.5i M/T Calif Emmisions:
So i just removed my kick panel and I see that my fusebox has two white plugs in it already where you would think the diagnostic plugs should be going to.
Those plugs are white.
I also see a random blue plug not plugged into anything that was slightly above the fusebox.
Anybody else remember what their 2005 M/T fusebox with diagnostic ports looked like?
Possibly the white wire plugs inserted into the fuse box are the diagnostic plugs and they were just left there by the previous owner? Not sure.
NOTE: This is the fusebox near your left knee. There is some confusion about location. Maybe I have the wrong fusebox.
The ECM looks to have already been replaced once.
Lawn ornament XT
The ones in blue tape up near the top look more like the drawing attached to post #15. Haven't tried it on an '05 myself.
21 - 40 of 66 Posts
