'15 Limited White/Black ES,Nav,Moonroof,Powergate,HK audio '15 Premium Wilderness Green/Ivory Eyesight Powergate
Going to change the radiator fluid in my '05 outback 2.5L and just wondering as I don't have access to my manual at the moment on how many gallons of anti-freeze I need. Is one gallon with the subaru radiator additive enough?
Going to use the Subaru stuff and was going to order it online later tonight. Thanks for the help.
2006 Outback 2.5i
That along with a gallon of distilled water and you will be good to go. If you look in the "Problems and Maintenance" forum there is a sticky with 2005-07 routine maintenance PDFs. Check it out they are very helpful for doing the routine stuff:)
Be sure to follow the bleeding directions on the gallon of coolant as well.
Banned
2007 Outback XT Ltd
My '07 Service Manual says the 2.5i has a 6.3 or 6.4 qt capacity, depending on tranny. I gallon should be fine as long as it is full strength and not diluted 50/50.
John Davies
Spokane WA USA
Thanks guys
