Hello, I am new to this style of forums, but I am determined that others are the best way to resolve my problems with my new Subaru.
Here is the backstory: Bought a 2005 Subaru legacy Limited 2.5gt wagon Tuesday, 11/12/19, I test drove it, felt smooth, fast, very clean car no lights or issues. Not knowing the last time oil or maintenance was done on the vehicle, I took it to my local imports shop, who specializes in foreign model cars. I had them do medium service described by them as:
So drive home, no problem. Untillllll the next day Saturday morning 11/16/19 I am driving 35 miles to a farm I work on. Country roads, I planned on testing speed, enjoying the drive. I'm going 60ish and finally figure out how to turn on cruise control. Flick it on, then off just to test it. few minutes later.....
BAMMMMM
CEL light is glowing like a christmas tree, and that cruise light is flashing. A depressing 80 miles into owning this vehicle. I do some research and it seems it can be a light fix or a big expensive lemon.
I take the car in and get it scanned by an Auto Zone OD2, and it says Cat needs replaced because of a P0420, Well heck me right? So I do some more research and find out maybe it is an 02 sensor, before or after the Cat, or maybe a Vacuum leak, or something.
So here is the facts:
05 Legacy 2.5turbo, 150,000 Miles, I have drove it for a total of 150 miles, Filled the gas tank up once with premium fuel.
CEL light on, and blinking cruise light,
CHUGGGING through gas like no tomorrow,
awful MPG,
and after having the air on for awhile I get a not so pleasant smell from the vents.
What do yall recommend? Should I go back to the shop and ask if they messed with something? Is this a by chance accident? Should I contact the dealer and see what they can do/say? It was a small dad and son cash only place in town. Do yall think this is something I can fix myself? Is this a lemon?
- Adjust Idle Mixture
- Inspect & Adjust Drive Belts
- Replace Engine Oil & Filter
- Inspect Air Cleaner Element
- Inspect Throttle Body
- Inspect & Adjust Timing
- Inspect Ignition Wires
- Adjust Rear Brakes
- Adjust Parking Brake
- Inspect Front Brake Pads
- Inspect Rear Brake Pads
- Inspect & Adjust Clutch Free Play
- Inspect Exhaust System
- Inspect Power Steering System
- Inspect Suspension System
- Inspect & Adjust Tire Pressure
- Change Transmission Fluid
- Rotate & Balance Tires
- Lubricate Door Hinges, Locks & Latches
- Road Test
BAMMMMM
awful MPG,
