2005 Subaru Outback 2.5 xt Limited
Fluids seem fine, but there is the "bubbling sound" present in the dash constantly when I have the key turned to ON. Battery and cables are fine. It won't start once it's warm but starts up fine when it's cold. I know I have a coolant leak somewhere, but it seems unrelated.
I unplugged the sensor on top of the air filter and tried while warm at the suggestion of a friend, didn't help.
Any suggestions? I've read camshaft sensors and coolant sensors could cause this.
03 H6 OBW & 06 WRX Sportwagon
key-on sound might be a blend door in the climate system
does it crank when the warm start failure occurs? if so, does it sputter? If not, does jumping the car start it?
Sorry, I should have specified. There is no crank at all when I turn the key.
I haven't had a chance to try to jump it, but the battery has sufficient voltage and everything.
Master Caster
Oh...no crank, but good battery voltage?
Main negative ground to the starter.....try that. bet it is corroded.
