1 - 11 of 11 Posts
05 OBXT Manual, 05 3.0R OB Manual (Moded, R.I.P.)
I recently went stage 2 on my '05 obxt. Currently installed is: invidia catless up-pipe, cobb catted downpipe, and cobb CAI. Also worth noting is I have a non-oem catback exhaust without a resonator, but still a y-pipe style out to non-oem mufflers, however diameters are oem. Purchased the vehicle with it on already, definitely going to be replacing eventually.
Anyways, I'm running a cobb stage 2 + sf v300 on 91 normal wastegate and am missing boost target by about 3.5psi. I'm running v300 because my cobb DP is older and doesn't have the new GESI cat, so I pop p0420 on v400. I have tried v400 normal and HWG though just to see. I get pretty much the same results in my logs with any of the tunes. I have a log here and just want to see if anyone has suggestions on where to start searching since nothing is jumping out at me.
I have done a 120K service on the vehicle, and removed the intake manifold, replaced quite a few gaskets and o-rings, new spark plugs. I wasn't able to do all of the vac lines I would have liked, but I did not see any obvious cracking. My intercooler appears fine as well. During DP install I checked my turbo and it felt really solid, wastegate also looked good. Also, my A/F learning A,B,C are all within +/- 5 range...so I'm kind of stumped. But maybe i should just go ahead with a boost leak test?
I guess you found an older map? Cool!
Haha I did! I dug around and found an older one, so no p0420 code popping, but alas now I have this issue which is irritating the **** out of me…probably gonna get under the car this weekend to double check all of my work and move to a boost leak test. I really regret not datalogging on stage 1, but didn’t feel the need since my boost always seemed correct for my elevation+conditions and fuel trims were good. At 6000’ With stage 1 hitting 10.2ish psi where target was likely around 11.5psi. So maybe I had a tiny boost leak there that has become more apparent with stage 2?
But yeah since I’ve already gone stage 2 without fully investigating stage 1, I now just have that more to check out, lessons learned for sure.
A boost leak test was my thought too.
Have you zip-tied all vacuum lines ?
For sure, worth doing just to rule things out. But here's what sort of throws me for a loop, my AF values aren't that off. I would think with a boost leak I would be seeing AF values being pretty off and positive? I'm seeing negative AF values within the 0 to -5 range. Or is this not necessarily true/I'm not thinking correctly?
Did you upgrade your turbo inlet pipe? Mine is pretty worn out but I have the Cobb one to put on at some point.
Yeah during my 120K service I noticed the turbo inlet was starting to tear pretty good at that hose clamp. I had a cobb inlet, but one of the inlet hoses wasn't connecting properly, think some hardware was missing or was sent the wrong one. Man I was so pissed at the time, cause I HAD to have the car running the next day so I had to run down and get a new stock inlet. Super annoying cause I know how much of a PITA the inlet can be without the intake mani removed, so yeah double payed and double worked lol.
Hadn't been driving much, so just got back to maintaining it. Upgraded to a GS TMIC, stock one was definitely leaking a bit, and gained a fractional amount of boost, but didn't solve the issue. Then replaced a ton of vac lines and found the issue. The wastegate to turbo hose (one with the T and restrictor pill) was not stock and was some crappy "aquarium-like" tubing with no restrictor pill. Admittedly, I should have checked that line out way sooner, but that was definitely the issue. Now getting the correct amount of boost and good fuel trims :)
1 - 11 of 11 Posts
