Our outback rear hatch quit working a couple of weeks ago. I couldn't find any DIY's on how to fix it, so last week after the ski area closed I dug into it. I must say it was quite inconvienient not having access to the rear of the wagon for a few weeks.
First I removed the small cover at the bottom of the hatch from the inside. Pry it down from the top first and pull down. Then use a flat blade on the drivers side of the actual latch, when you get it exposed, where shown to get the hatch to open. Make sure you move the white lever down to unlock the latch (picture shown without White locking mechanism in place).
Then you need to pull the sealing strip off the bottom of the hatch and remove the four plugs that hold the rear hatch cover in place at the bottom. Next remove the small cover on the pull handle via a small flatblade screwdriver right in the middle of the flap as shown and remove the two phillips head screws.
