1 - 7 of 7 Posts
2006 B9 Tribeca Limited 7 Pass.
I searched the forum for this issue, so I apologize if it's already been discussed.
Car is at about 106k.
Anyway, it's in the mid 90s here in Texas and if I am sitting at a stoplight or a drive thru for just a few minutes, the temperature guage will go just one notch above where it normally rests. I'll turn off the A/C and it will go back down to normal after maybe a minute or so. It never has an issue if I'm driving or anything like that. I had the coolant changed about 10-15k miles ago, Im just curious if anyone has experienced this in their H6.
Lawn ornament XT
Check your cooling fans to make sure both are operating. If the tribeca works the same as the legacy & outback, both should run when either runs, and the bigger one is allowed to step to a higher speed.
This link about fan motor failure may be useful.
And another.
Thanks everyone for the quick reply. Both fans are working as far as I can tell, and there has been no coolant loss.
2006 WX8: my "Outback" > yours
If there hasn't been any loss, hopefully it's just air left in the system after the change. On Tribeca in particular, there's a specific air bleed procedure shown in FSM.
2013 OB 3.6R (former)
Hm, how much do you trust your mechanic? If you do, I would take it right away. The B9 does have an issue with cooling--it was never able to make steep interstate grades when loaded and at temps over 105 with the AC on--something the OB has no problem doing--but what you describe should not be happening.
90 deg would count as a beautifully refreshing day here (though we do not have your humidity).
2005 Outback 3.0R
Could also be something as simple as the radiator is plugged up with dust and/or insects.
1 - 7 of 7 Posts
