1 - 13 of 13 Posts
2008 Outback 2.5i 5MT Newport Blue Pearl
Hi everyone, I don't want to beat a dead horse with the P0420 code but I want to know if anything in my situation might lead me to a different outcome than what I have read on different threads. I have a 2008 Outback 2.5i 5 speed MT.
A few months ago, my check engine light went on and flashed. Pulled up both the codes that indicated misfire on cylinders 3 and 4. The misfire was very infrequent and only happened every so often. Dealer said it needed new spark plugs and wires. I said ok do the work. Got it back from the dealer and it behaved fine for a few weeks. I was away for a few weeks as well so I didn't drive it obviously. Well check engine light has returned and is flashing, codes are still for the cylinder 3 and 4 misfire and now the P0420 code. I really don't think the cat is bad because I am getting excellent power and gas mileage when it is not misfiring. It will misfire now intermittently and then be back to normal. I have also noticed a strong gasoline smell from the exhaust, most noticeable when misfiring. I am going to replace the front O2 sensor. And then if that doesn't work then will look at adjusting fuel valves. What action do you think I should take. I really do not want to take it back to the dealer if I don't have to. Thanks for all the advice.
So I took it to the dealer and under the SULEV warranty they replaced both catalytic converters, oxygen sensor, and air flow sensor. Bringing it home the car operated fine. I took it out later today and upon pulling out onto the main rood from my street, the car started sputtering again. Obviously misfiring. It did not throw a code though. As I was turning the car around, the check engine light flashed a few times and then shut off. I only went about a quarter mile between leaving the house and turning around. When I got home, I tried to pull up any possible codes on the dashboard and it didn't have any. I am at a loss of what it could be. Any ideas since replacing the converters and sensors didn't work? I did bring up the possibility of it being the coil pack and dealer was pretty decided that wasn't the issue. I'm thinking it could possibly be since 3&4 do share a coil and I don't want the misfiring to make this catalytic converter go bad by dumping fuel.Any ideas appreciated.
Thanks,
Kurt
2005 Outback 2.5i 5spd 400,000 miles+
If it was mine I'd go ahead and swap the coil, maybe do plugs and wires too if they're old or unknown when last done.
Ended up changing out the coil pack. Problem solved! Thanks everyone!
hope that was a OEM coil,...even a used one that says "subaru" on it.
or maybe a NGK/NTK one.
lots of aftermarket junk coils out there for these cars. (like so bad they make people want to sell a otherwise good car).
what dealership did the work on the car?
updated thread title.
2009 Subaru Outback 2.5i
I second what eagleeye said. On my '09 I initially replaced a failing coil (that was causing progressively worse misfires on 3&4) with an aftermarket one from NAPA. That coil only lasted about 4 months before it started acting up and doing the same. NAPA replaced it under warranty, but I was planning on replacing that warrantied coil with an OEM one as soon as I got a chance...but I ended up swapping engines to a later EJ253 that had Coil on Plug ignition so that kinda took care of that. LOL.
Discussion Starter · #11 ·
Premier Subaru in Watertown, CT. Yes I made sure it was OEM.
2017 3.6R Limited (Wifes), 2009 3.0R Limited 125k (Mine)
Many dealerships and mechanics have become nothing but parts changers. They did a lot of unnecessary work to your car when all that was wrong was a failing coil. Glad you finally figured it out, something the dealership or mechanic should have figured out immediately. Especially since 3, 4 share a coil. Hello…..Mcfly!
anyone can have a bad day but, according to google maps, Premier has the lowest rating of soob dealers in that area.
1 - 13 of 13 Posts
