The instructions are mostly clear. (Before disconnecting the battery and if you have power seats be sure to remove the console rear side bolts)
1. shifter cover removed.
2. wiring inside console.
3. console out.
4. console upside down. I did not drill from the inside as the instructions said. I measured the template and taped to the outside then drilled the 2- 1/8th" holes. The large hole should have been 15/16". Didn't have that size so I used a 7/8" and it worked fine.
5. After drilling.
6. Be sure to slide outlet harness thru the outlet mounting bracket.
7. Plug wires to outlet and screw the outlet to console and bracket.
8. Inverter measurements laid out using tape. Work very well. (I did not remove seat. I un-bolted tracks and leaned seat back)
9. Ready to cut carpet. I didn't find any wires under carpet/insulation but you should double check.
10. After cut and sound deadening removed
