Hello,
just traded my 12 Impreza for an Outback. Best decision I've made in the transportation realm. I have searched for the answer to this for a couple days, and asked my dealer. No one seems to have an answer.
How does one with a push button start 2013 Outback with the Special Appearance Package disable the beep when locking the doors.
Previous models had a sequence:
Audible Chirp when locking/unlocking give you an audible signal when the doors lock and unlock. If desired, you may turn the audible signal off.
Do the following to deactivate the audible signal. You can also use the same steps to restore the function.
1. Sit in the driver’s seat and shut all doors and the rear gate.
2. Hold down the UNLOCK side of the power door locking switch.
3. While holding down the “UNLOCK” side of the power door locking switch, pull the key out and re-insert it into the ignition switch at least 6 times within 10 seconds
after Step 2.
4. Open and close the driver’s door once within 10 seconds after Step 3.
5. The turn signal lights flash 3 times to indicate completion of the setting.
copied from:
http://www.cars101.com/subaru/keyless2010.html
Subaru Keyless Entry, Security Alarm, Immobilizer Key, Remote Start Systems. Most years and models
Thanks, and this is my first post, so be gentle
after Step 2.
copied from:
