1997 Outback Legacy Limited 2.5 auto
Last winter my rear wiper froze and will not move. Washer works. Can I replace the motor myself? Sorry but I can't afford a garage fee. Any DIY for Outbacks out there? Any help will be appreciated before the snow falls.
05 Xt beatin' to an inch of its life
You can. I remember having to take a cutoff wheel to one for some reason to get it apart tho.
2019 Outback Wagon 2.5i limited
Your Outback is ten years ooder than mine, but it’s probably quit simliar. It shouldn't be all that hard to do, removing the lift gate panels to access it may require a panel removal tool (not expensive). I had to replace my wiring harness and there are threads that tell how to remove panels on the 08 model. Follow this link;
https://www.subaruoutback.org/threads/2008-outback-rear-wiring-harness-replacement.411058/ There are a few diagrams showing how to remove those panels. Once in there, should be straight forward, disconnect plug and unbolt it.
Thanks, this should help.
