Hi all, new to the forum and looking for some help.
I am having issues with my sub fan not coming on (right side). To give some background. After replacing a faulty main fan, a few months later the subfan failed to come on and I got a P0483 code. I checked the fan and it seemed to be ok, no blown fuses, relays seem to be ok, so in a pinch I hardwired it so that it comes on whenever the car is on. I just did a little more digging and it seems like the relay is not getting any voltage, however all other relays are (see relay in attached picture). Any ideas or things I could check next?
All else fails I was thinking of bridging the high voltage terminal on the main fan relay to the subfan relay and seeing if this solves my problem.
'98 Outback
What wiring diagram are you using? I have two for my '98 and they conflict on this circuit.
There should be another sub fan relay in the fuse/relay holder under the dash. (Apparently it's the main fan relay if you don't have A/C.) I'd look at that first. It looks like one of the sub fan relays works with engine coolant temp, the other with the A/C system.
Does the A/C work okay?
if it gets too crazy tracking this down - you could rig the main fan to always be on when ignition is on.
I am using this wiring diagram from the jdmfsm website.
The AC works fine. Thanks for the tip, I will check that relay out and update.
The sub fan is already hardwired to be on with the ignition, but this doesn't solve the check engine light and I can't pass emissions testing in CA with a check engine light.
'98 Outback
That's one of the diagrams I use. Look at Section Z, relay FB-2, which also shows up in Section A, where it's called both the main fain relay and sub fan relay 1. Like I said, conflicting. Good luck with it.
it's a newer car, but I found this video;
evidently, the ecu is examining the fan ON signal and expecting a corresponding change in temperature from the ECT - so, could be a bad ect ?
